WARNING: Counterproductive "safety" features.
Ron50
10:01 PM
Canberra ACT, Australia
Oh … I see now.
Does your Grenadier have autonomous emergency braking?
Haven't seen any reference to it but this incident suggests it could have.
My understanding of how stability control works is that it brakes individual wheels to straighten the car up; whereas autonomous emergency braking slams them all on at once.
There was no oncoming traffic or even nearby foliage for the camera/radar to detect to suggest an emergency and I had not applied any braking.
In the circumstances, with light throttle and a reasonably high gear, all the wheels would have been travelling at the same speed so you wouldn't expect ESC to be triggered either.
So I'm in the unfortunate position of not even being sure of the causal factors so that I can avoid them in future.
If the car doesn't have emergency autonomous braking maybe there was enough throttle on the skatey loose gravel surface to trigger the ESC to apply the brakes on all wheels simultaneously.
Up to the point of the incident the car had felt as if I was in complete and normal control - no warnings that I was pushing things.
Michael H.
10:01 PM
Sydney, Australia
Mine definitely doesn’t have AEB, but I wasn’t sure if newer Aussie spec Grenadiers had it.
If you had it, you’d also have lane departure warning, intelligent speed assist and driver drowsiness detection.
Ron50
10:01 PM
Well, bugger, page 114 of the paper manual says ESC off cancels at speeds above 15 mph/25 kph. My test drive just confirmed this.
Shopkeep
10:01 PM
Maybe on dirt roads at speed you should have the centre diff locked and be in high, not sure if this alters or tweaks the ESC but might reduce excessive power transfer to any given wheel causing slip and reduce chance of ESC trying to intervene?
Michael H.
10:01 PM
Sydney, Australia
Just to clarify … it says that you can’t turn ESC back on (if you’ve deactivated it with the ESC OFF button) at speeds above 15mph/25km/h.
And it's wrong by the way. You can turn it back on at any speed.
It’s been corrected in the electronic manual.
chrsbe
12:01 PM
Sternwartestraße, Wien, Österreich
I had a very similar experience in my Suzuki Jimny which has a passenger detection via camera system. It was ether this system or dirt on the abs sensors that caused an emergency brake without reason. So i guess it is not a Grenadier problem. It is these systems that needed to be turned off on dirt tracks.
With my grenadier i experienced a lot of false esg interventions while driving through very very loose sand. Hitting esg off button helped and solved the problem.
Ron50
10:01 PM
Worth a try. Thanks.
Michael H.
10:01 PM
Sydney, Australia
Locking the centre diff puts ESC into off-road mode, which desensitises it.
Ron50
10:01 PM
Thanks again for your input, Shopkeep.
After my last test drive I found that my car behaves, in accordance with the manual, as follows:
Normal mode with ESC off button pressed holds until 78 kph then ESC becomes fully enabled.
Centre diff locked without ESC button pushed maintains ESC off road mode from low to very high speed.
Centre diff locked and ESC off button pressed holds from low speed to 78 kph and then transfers to ESC off road mode and will hold it to very high speed.
Panic braking on sealed surface seemed consistent with normal ABS operation - no detection of autonomous emergency braking.
