- Local time
- 4:23 PM
- Joined
- Oct 17, 2024
- Messages
- 18
- Reaction score
- 8
- Location
- Canberra ACT, Australia
After my experience yesterday I'll never be able to fully trust my Grenadier again.
I had enjoyed trying out the car in steep terrain and found that I hadn't needed to use low range or lockers but had switched on Off Road mode anyway.
When I got onto a major road that was still unsealed I watched to see that the Off Road mode had cancelled with increased speed - as it is supposed to.
As I approached a minor right hand kink on a fairly straight bit of road the car suddenly decided it could do a better job of driving than I could, slammed on the brakes and sent me into a ditch.
I had mown down a couple of flexible plastic posts but no real damage was done. However the steering now veers right slightly and the steering wheel is a few degrees off to the right. I'm hoping a wheel alignment will be all that is needed to correct this as I can't see anything bent or out of place in the front end.
I can't be sure whether it was the autonomous emergency braking, stability control, ABS or a combination that caused the car to go haywire for no obvious reason but it has destroyed my faith in the electronic "safety" aids of the Grenadier.
Perhaps if I had switched off the stability control as I always did on my Pajero on unsealed surfaces this would have prevented the problem - that is, if it doesn't automatically switch back on above 70kph in the same way Off Road mode switches off above that speed.
The stability control effect on the ABS on the Pajero made it feel as if the brakes had failed on loose surfaces, especially in 2WD, which is why I turned it off when I remembered.
Has anyone else had a similar experience?
