View multi-screen Infotainment
Paco Garcia
6:04 AM
Valencia (España)
Hi friends, I think I read it somewhere on the forum, but I can't find it. The option to see the maps and at the same time information about the music you are listening to on the infotainment screen can be done in all models or is it from a specific date or update, and if it is possible, how is it configured? I am referring to this, it is an image taken from a forum thread
Regards
Paco Garcia
bemax
6:04 AM
Regards
Paco Garcia
i have not seen this on CarPlay. Maybe it works with Android?
Paco Garcia
6:04 AM
Valencia (España)
Hi Bemax, I don't remember where I read it, either here on the forum, or in some Facebook thread, that it could only be done on 2024 models, or that they had the software updated to the latest updates, it could also be what you say, I also use Apple Car Play, let's see if someone can clear up our doubts.
Regards
Eric
5:04 AM
Scotland
Regards
Paco Garcia
You have intrigued me, I'm on AA and certainly can reduce the map screen to half size, but haven't played, via USB, any music " art work". Next time I use the vehicle I'll try it. I'm on ...1946 software
Paco Garcia
6:04 AM
Valencia (España)
I'm away from a vehicle at the moment, but in CarPlay it's the little dots below the vertical App icons. I believe you tap once to view Apps, tap a second time to get to Split View.
(Generic CarPlay image I found)
split-screen-png.21925
Thanks Tom, I just checked and it's like you said, in Car Play when you have more than one app open you double-tap on the small squares and multi-screen appears,
Thanks buddy
Paco Garcia
6:04 AM
Valencia (España)
No he visto esto en CarPlay. ¿Tal vez funcione con Android?
Me has intrigado, estoy en AA y seguro que puedo reducir la pantalla del mapa a la mitad, pero no he reproducido, vía USB, ningún "art work" musical. La próxima vez que use el vehículo lo probaré. Estoy en el software...1946
Tom109, has given us the solution this is a great forum for help. Thanks again Tom
BD1
11:04 PM
Illinois
This view also allows you to open/close your garage door (if you have a add-on to your garage door opener):
