Which ones Dave? I mean I get vibrations at 500rpm when I'm not giving it enough in the manual Triton off the line but at speed of any kind I've never felt this in the 6 or so cars I've driven recently.
You asked "can anyone advise"Which ones Dave? I mean I get vibrations at 500rpm when I'm not giving it enough in the manual Triton off the line but at speed of any kind I've never felt this in the 6 or so cars I've driven recently.
Has all the underbody insulation been ruled out?It is clearly the sound of the transmission or something in the drivetrain reaching a resonance frequency and I would describe it as more of a buzzing noise.
I asked what other cars Dave - you read-only read half of something. Too cute with words? Another was happy to note his R8 had vibrations - which is useful being a European vehicle... just saying.You asked "can anyone advise"
My answer was yes.
Anyone can advise.
You see this is what I am trying to see if maybe a problem exists at speeds people routinely sit at... if something is vibrating at 100kmh then that would be a problem!!! Maybe it's just a running in issue.I get a bad vibration at around 2300 rpm in my work mercedes sprinter tipper. It's annoying on the motorway as in 6th gear 2300 is about 60mph.. the speed I want to be sitting at
Yes but you have asked a question with a million possible answers.I asked what other cars Dave - you read-only read half of something. Too cute with words? Another was happy to note his R8 had vibrations - which is useful being a European vehicle... just saying.
Be reassured that the surface rust on the wheel bolts of my 1973 Land Rover hasn't progressed in 49 yearsI feel for them and feel bad that I hope it doesn't happen to me.
The surface rust on my Fiat has eaten away half the vehicle.Be reassured that the surface rust on the wheel bolts of my 1973 Land Rover hasn't progressed in 49 years![]()
If you know the story , this was only an issue with the Russian steel ones. My '64 sat in a carport on a farm for 30 years and was/is still pretty much rust free, The steel is thick and strong, most unlike any modern car.The surface rust on my Fiat has eaten away half the vehicle.
Said every Fiat owner ever.
That applies to a lot of Landcruiser owners in the U.K. too. Before finally deciding on the Grenadier I was checking out circa 20yr old Landcruiser’s for potential overland build. Most were rotten with rust.The surface rust on my Fiat has eaten away half the vehicle.
In regards to the vibrations many seem to be feeling on their new Grenadiers, it reminded me of having the same thing happen on a couple of my Range Rover
Sports, where I was feeling a vibration at certain rpm’s through my steering wheel.
One was related to the tires/rims needing much better balancing, which was resolved by having the tires/rims balanced on a road force balancer.
The other time, Land Rover decided to eliminate and not install a transfer case damper, which basically looked like a rubber donut on the outside of the transfer case. I had found the Land Rover Technical Bulletin, (LTB00305), on line on a Land Rover Forum, and gave a copy to my service rep. He did not think that was the reason I was experiencing the vibration in the steering wheel, however he ordered one and had it installed. Completely cured the vibration. Please see the link to that bulletin and look at page 2 where they show what the donut looked like. Not sure if either of these are the causes of the vibrations on the Grenadier some are experiencing, however perhaps a good place to start looking. Da Bull
https://static.nhtsa.gov/odi/tsbs/2013/MC-10214006-9999.pdf
And for the Alfasud, where the unprotected unpainted chassis (russion steel and non russion steel) was moved between the buildings, near the seaside and when the workers council called for a workout they were sometimes left outside for a few days. After that they brought them to the paintshop to conserve the drama.If you know the story , this was only an issue with the Russian steel ones.
Bushes.i had it happen as well. it was a gen 1sh rr that i bought in the 90's.
i don't know what caused it. i do know that it felt unsafe going around 65. not to mention all the road wandering it had. these were pretty shitty vehicles. i sold it because i thought was going to die driving it.
Bushes.
Suspension
Wheel balance and alignment
Bearings
lack of maintenance.
I assume Diesel. Is it something you've taken up with Ineos and if so what have they said? I'm expecting delivery of a diesel next month and hence the concern. is it getting any better?Mine does have a vibration somewhere in the engine bay at 1500 to 1600 rpm as it goes through the gears. Same cold or hot.
