Vibration at Idle
Hannes
12:45 AM
Bavaria, Deutschland
Hi all!
Have my Grenadier for 4 weeks now and 1700km on the clock. Today, standing at the traffic lights, Gear in "D", the whole cabin started to vibrate. It feels like the Gear wants to build up torque and loses connection immediately (frequency anywhere at the engines rpm). Vibration stops instantly when touching the gas pedal just slightly and speeding up the engine a little bit.
After restarting the engine, it is mostly gone but returns after a couple of seconds. Anybody else recognized something similar?
Thanks!!
Fixed it
Had to remove a small rock lying between the Gaerbox and the Transfer Case connecting both to solid unit. The rock transmitted the engine vibrations to the Transfer Case to the Frame so thtat the whole cabin was shaking.
Maybi it helps somebody else...
Hi all!
Thanks!!
Yes, I also have a vibration at idle.
Hi, have you checked the space between Gear Box and Transfer Case for Debris? You can't see it. I crawled under the car and tried to find something with my hand. After removing a small rock the vibration was gone.
