USA 7 Pin Round Brake Controller Wiring
nodric
6:38 PM
Dallas, TX, USA
Exhausted searching for this, so if I missed it let me know. USA 2023/24 spec has a 7 pin round trailer electrics connector. Pin 2 should be a lead that is wired for trailer brakes, but given there is no brake controller fitted stock I am wondering if this lead is wired in the socket, and if so what for, and where it is terminated inside the car? The idea being to find that termination and connect it to the brake controller to avoid running wires to the socket and butchering the socket wiring.
If this makes sense to you and you have done this I'd be happy to learn how. It seems if it is wired then cutting it and splicing to the brake controller will provided the needed brake control for electrically braked trailers.
It's absolutely wired into the socket, the interior termination for adding a brake controller is found under the right rear seat, you'll find all the wiring you need to tap into.
From the notes I have, they are all blunt cut (there are photos in other threads); Yellow/Red is power, Black is ground, Violet/Orange is the signal, and Grey is the control wire
Upvote 0
Wires under the back seat
Upvote 0
Don't US vehicle have fog lights? Sorry rephrase that, don't US trailers have rear fog lights? They are mandatory on all trailers in the UK and EU
Upvote 0
Not at all
The US doesn't understand the purpose of rear fog lights, thus why most manufacturers either don't offer them on US-bound vehicles, or if they do, they have added one on the opposite side so they have dual rear fog lights. Decades ago, when most US-spec Euro vehicles had the traditional rear fog on the driver's side, countless people got pulled over and given citations for having "a light out".
Now that most of the remaining Euro brands that still have the rear fogs on their US cars are dual rear fogs, people treat them like front fog lights, and turn them on in normal (non fog) conditions.
In the US trailers are only "required" to have tail (running) lights, 2 brake lights (which almost always run double-duty as turn signals, as we almost always use red rear turn indicators), and depending on their width and/or length may require a few extra running lights along the side/rear. No rear fog, no reverse lights, etc.
We have 2 different trailer hook up connections, either a 4 pin (earth, tail lights, L brake/turn, R brake/turn), or a 7 pin (earth, tail lights, L brake/turn, R brake/turn, reverse, trailer brake activation, and 12v positive supply).
Upvote 0
Being a Brit I hate hate hate fog lights, mainly as endless drivers think they should turn on 21w bulbs in the rain, or simply forget to turn them off when the odd foggy day has passed. It's a blessing not to have them here. The unwritten rule in the states is we turn on our hazard lights in poor visibility. We at least remember to turn them off again.
Now, the lack of reversing lights has always bemused me.
Upvote 0
Depending on where you are in the country, there's also the unwritten rule of turning hazard lights on in a light drizzle and slowing to 20mph below the speed limit :ROFLMAO:
Upvote 0
Trailers under 750kg, ie unbraked, don't require reversing lights. Above 750kg reversing lights are now also mandatory.
Upvote 0
Connecting the supplied 13 pin Euro socket to an Australian 7-pin wired camper and adding the missing electric brake circuit was a joyous task given that IA didn't fit pins 10 thru 12. ISO11446 sets the 13 pin Euro wiring standard and colour codes and IA didn't follow it. I had to run a new circuit to create pin 12 to connect to pin 5 on my camper for the electric brakes.
Upvote 0
Connecting the supplied 13 pin Euro socket to an Australian 7-pin wired camper and adding the missing electric brake circuit was a joyous task given that IA didn't fit pins 10 thru 12. ISO11446 sets the 13 pin Euro wiring standard and colour codes and IA didn't follow it. I had to run a new circuit to create pin 12 to connect to pin 5 on my camper for the electric brakes.View attachment 7850866
Yes, I don't understand why IA didn't follow ISO11446 nor drop the 3 pins either. There must because lot of caravan and camping trailer owners very p...ed off.
When I ordered mine I specifically asked their customer services was it a 13 pin socket, I should have asked was it an iso11446 European 13 pin socket.
Upvote 0
CAUTION - on the US spec IG’s it is widely know, on the Forum, but not beyond, that the Violet/Orange line under the seat DOES NOT send a brake signal. As a result, people think they have a functioning brake controller, and trailer brakes, and they don’t. This is a really dangerous situation and INEOS should be sending out some kind of recall but they aren’t - yet. They know about the issue and I was instructed to cut and splice wires at the TRM (trailer module) but that is not the answer. This vehicle was market and sold as being “trailer ready” with all the wires ready for the controller. The fact that they got this wrong and there is no trailer brake signal is a massive risk and issue. I have been told that Software won’t fix it so bring on the hardware. Most likely a replacement of the TRM.
If you have a TBC installed and rely on it - test it. This is not an isolated issue and I’ll bet it is an issue that all of the NA vehicles have.
Yes - software updates done earlier this week and still the exact same issue.
Upvote 0
Very concerning indeed.
Is this on all NA vehicles or a selection thereof? Where on the forum is this issue discussed? Did cutting and splicing wires at the TRM serve as a functioning work around? What brake controller were you wiring in? (Not that it should matter, just curious).
Upvote 0
Another reason I sold the damn thing. If this is real, and no reason to doubt that, then someone somewhere should reporting it to the NHTSA!
Upvote 0
Here is the thread.
Yes - most people that needed a workaround have had to run the trigger wire themselves.
I got a formal response from the dealer this week after they talked to INEOS and even INEOS recognized the issue and suggested running a rigger wire OR just taking the Violet/Orange line out of the TRM and splicing it into the Blue/Orange.
This would indicated that the hardware is wrong (the TRM) and they know it. My guess is that to fix the issue they would need to install a new TRM and they likely don’t want to do that on a couple thousand vehicles in the US.
What I haven’t heard about is any kind of part number changes and/or if there is a fix being applied to new vehicles. I guess that’s next on my list - see if there is a newer part number and try that part to see if it will fix the issue.
Upvote 0
Here is the thread.
The fix wouldn't be a new TRM, it would simply be to edit the software for the TRM.
From what I have heard, since the trailer brake controller pre-wiring isn't officially supported, it is beyond at the bottom of the list of things to work on.
It is easy enough to simply jump two wires at the TRM in a matter of minutes, or run a new trigger wire up to where the rest of the blunt cut wires are. From speaking to a handful of folks that have brought this up to their local dealers, those dealers have contacted Ineos, been told which wire needs to be jumpered/run and taken care of it for the customer
Upvote 0
I hear you on simplicity and agree, BUT - since the pre-wiring is not correct - it is a defect and INEOS needs to fix it.
The dealer asked INEOS and was told that there were two options - 1 - run a trigger line off of Blue/Orange to the controller or 2 - clip the Violet/Orange line and then splice it into the Blue/Orange. This suggests that Violet/Orange only goes from the TRM to the blunt cut wires under the seat. INEOS also suggested the use of a DIODE under either option.
There are a number of wires going into and out of the TRM and quite a few blanks. I doubt it’s fixable from a software fix and more likely a situation where the wire is pinned to the wrong location. The TRM should have a built in diode and the whole system should work just like any of the other vehicles I have added the REDARC to.
Can I do it sure. Do I want to do something I shouldn’t have to - no. If this a defect - yes. Should INEOS fix it - yes. The fact that INEOS did even suggest that it was their issue and have the dealer run the wire as a defect repair is my issue. They also didn’t even suggest they were working on a fix and what that will be - software or hardware. Regardless - INEOS needs to come up with a solution and they need to make the fix as the vehicle is not what they marketed and sold.
Upvote 1
I don't think a fix is in the works; and I'm not sure, but has it ever been marketed as being pre-wired for a brake controller?
Upvote 0
Yes - it has and is marketed as “pre-wired” for trailer brakes. It’s part of the tow package marketing.
It is a reasonable expectation that what was installed in the vehicle should work.
+1 on this as all the 4x4s with towing capabilities that i have bought in the last 20 years have had this as it's a critical safety component when towing larger items. And I did buy this specific model with the intent of towing periodically. So INEOS needs to address this, and no put it on the end user.
Upvote 0
