Trialmaster Specifications Questions
Steve A
1:01 PM
Grapevine, TX, USA
I have some questions about some items for the Trialmaster.
Will the High Load Auxiliary Switch Panel & Electrical Power Take-Off 400W, for work for a winch?
Is the receiver hitch a standard 2”?
What are the Light Bar Provision Pack Prot and Winch Pack Prot?
Thanks
The high load auxiliary wiring will support a winch, one of the switches is a high amp switch specifically for a winch. The option and that switch are used by the factory installed winch.
The hitch is a “standard” 2” receiver, though some on the forum have reported that the tolerances are a little tight and some “standard” hitches don’t fit. Might have to try a few. I have the tow package and it came with a hitch and 2” ball.
No idea on the optional packs.
Thank you. If the receiver is a bit small I and a couple of grinders I can shave down some hitches, a snug fit wont rattle,
Thanks
Yes and yes, in the US.
I solved the hitch diameter question between 50 mm and 2 inch hitch / receiver. Some of the early deliveries to other (metric) countries had a 2 inch diameter hitch supplied to 50 mm receiver. While close, they caused fitment issues.
