That's cause for slight concernBtw the transfer case that failed and removed was a “B” version already.
Maybe, but I guess any component can have a manufacturing fault, so will have to see if more emerge.That's cause for slight concern
Hi, did you manage do get the little pin back in again? I have the same problem right now- pin fall out (I have it) but can nit get it in again. Eed some help here…..Stolen this picture from Jean.
Locking mechanism should be under the leather jacket!View attachment 7831953
Will try it tomorrow!Hi, did you manage do get the little pin back in again? I have the same problem right now- pin fall out (I have it) but can nit get it in again. Eed some help here…..
What sort of magic pin is this?Phoned the workshop.
The pin is not available separately, the complete gearshift has to be replaced.
An approx 10 mm long maybe 1,5 mm diameter pin of hardend steel, that fixes the ring on the leaver. The ring that you have to lift up in order to make a change from high to low or Center diff lock.What sort of magic pin is this?
PNAdress!?
That sounds exactly like the problem I had.Now I am a victim of the transfer case problem too: Cannot engage Low.
Picked up my Grenny 3 weeks ago at the agent who had done the software update and various smaller repairs. He told my that they had changed the transfer gearbox also as part of an INEOS technical measure. Today first time I tried with the new transfer case - no success . The old one (I have an early build from Dec 22) worked w/o problems.
Center diff can be locked in High, but switching to Low is not possible. And yes, it had been in Neutral.
I am really annoyed.
I tried to insert a 1.5 mm drill bit and found the inner hole, but it still didn't work!If somebody can take accurate measurements of the pin it may be easy to find a suitable spare.
HSS drills are easily available at 0,1 mm steps and they are hardened steel. Cut suitable piece from the smooth end, and fit using suitable retaining compound, like Loctite 603.
Knock a few burrs offAs a FYI, Bill Burke (US offroad "Guru" did some serious wheeling with a Grenadier and reprted the transfer case was initially very stiff, but by the end of the day and many Hi-lo swaps, it was a lot easier. Looks like the transfer case just needs a bit of breaking in... I'm thinking of giving it a good exercise while driving round the block at the dealers to check this (and I want to see a signed copy of the pre-delivery checklist and talk to the technician who did it), all before I take delivery!!!
