Towing Hitch
Hi Rovie this is what I'm using to drop the ball height.
It's illegal in the UK unless it has type approval with the towball fitted. LR defender and some Toyotas are the only vehicles I know that have type approval for a drop plate. The tow ball height is stated in the regulation at 320 -400mm when the vehicle is loaded
The towing hitch, especially the ball joint, is not height-adjustable. The two upper pairs of holes are smaller in diameter and are not intended for mounting the ball head.
The distance from the ground to the centre of the ball is 53 cm. I have a problem with this.
The double-axle trailers I pull need a height of 40 cm so that both axles are equally loaded.
But I can't just make an adapter plate that screws in between. Because this has not been officially tested and officially approved.
Have any of you had such an issue in the past? What do you suggest?
I cannot adjust the height of the trailer.
S.o.
Don't you just use this type? I know they rattle a bit in use, but type approved etc
Sorry it is 350 - 420mm, I was using the phone and just recalled what I thought were the heights.
Two issues a) it is the drop plate actually fitted to the towbar that the vehicle manufacturers have to obtain type approval for there use. I doubt IA will have type approval because of b)
b) the holes in the tow bar are not aligned to the standard drop plate holes, only the bottom 2 are M16 holes and spacing the other 4 are smaller and closer together.
I had identified it as an issue because I have a number of trailers and horse trailer. My plan was wait until I get my hands on the vehicle first. It is not a showstopper and IA will be fully aware of the EU regulations. It may be when coupled the vehicle settles to an acceptable height.
I had such a height-adjustable tow hitch on my Defender, originally from Land Rover.
I agree with what you said. Yes, I have no choice either. Wait and see and try it out. But I think the trailers are coming too high.
There’s a thread somewhere discussing tow hitches. I think the 2” receiver hitches are not type approved in the U.K. and EU and that you may get away with using them on N1 vehicles only. I’ll try to find out more 👍🏼
I think there is a reciever hitch that takes these (my old range rover L322 had that setup think that had a westfallia hitch) this arb one has E8 ratings.
That looks pretty flimsy for something coming out of ARB - I’m not sure if I’d want to tow much with that.
This is what I use to lower the tow height when I’m towing the camper. As solid as Thor’s hammer.
I think you'll find that picture is computer generated and the 4 upper holes are smaller and closer together for a towball
Maybe only for Germany?
found this in German by Google:
„Die Kupplungskugel der AHK muss im beladenen Fahrzeugzustand in einer Höhe von 350 bis 420 Millimeter vom Boden entfernt sein“, sagt Thomas Caasmann von der Gesellschaft für Technische Überwachung (GTÜ)
Zugkugel-Kuppllungen für Anhänger werden nach DIN 74058 bzw. ISO 1103 mit einer Höhe von 430 ± 35 mm gebaut
translation:
"When the vehicle is loaded, the coupling ball of the hitch must be at a height of 350 to 420 millimeters from the ground," says Thomas Caasmann from the Society for Technical Monitoring (GTÜ).
Ball couplings for trailers are built according to DIN 74058 or ISO 1103 with a height of 430 ± 35 mm
So we have a standard in Germany that should be met when Ineos is approved!?
If you are towing a significant load, remember you want the trailer pivot point ( tow-ball ) as close to the rear wheels as possible for stability reasons, ( less weight transfer ).
So having the shortest tow-bar tongue possible will help.
That is one of the reasons that a current Defender 110 is a more stable towing platform compared to a 200 or 300 series LC. The 300 series has approximately 1.3m from rear wheel centre to tow bar. The Ineos has approximately 800mm from its rear wheel centre to the tow-bar, and a slightly longer wheel base so the Ineos should be a fantastic tow tug, I look forward to reading the Ineos towing reviews in hopefully the not to distant future, and like everyone els here testing it ourselves.
If you are towing significant weights often the weight out front of a roo bar and winch are not bad things.
