Big FF user.
I Have used this for the past two seasons on my daily driver (2007 4Runner) and also on my dedicated off roader (2011 Tacoma)Has anyone used this product from Blaster?
I’ve seen a fe different videos/reviews and it looks promising.
SURFACE SHIELD
FWIW (sorry @Jean Mercier) I plan to use Blaster Shield on the Grenadier.
It comes in both aerosolized cans as well as raw form in bulk buckets. I cannot speak to its exact formulation (or the aerosol cans), but I can tell you The raw form is not flammable (I use this in conjunction with an air compressor and sprayer gun). We had concerns about this so we put a glob of it on the garage floor and hit it with a propane torch and nothing happened.Yes it has Lanolin in it but the driers preclude it from being painted over (so I presume it never sets), it has a cedar perfume added, it's not bio-degradeable, it doesn't stop rust (you need a tannic acid for that) and it comes in a spray can.
It contains a petroleum distillate and compressed LPG which makes it highly flammable.
Around 10% is lanolin.
Great marketing though.
Surface Shield FAQs - B'laster Products
blasterproducts.com
Looking for a permanent 1-time hard shell coating for your truck frame or equipment? Hard-On by woolwax™ is what you need. Originally developed as a chip guard for trailer trucks this formula is perfect for any long term applications. Hard-On is water based , so it has almost no smell. Dries to the touch in about 1 hour, and after 72 hours it is fully cured.
Hard-On by woolwax™ was developed to be used on both ferrous (steel, stainless steel, cast iron, and wrought iron) and non-ferrous metals (aluminum, brass, copper, tin,). In addition, this formula will adhere to primers and oily steel. Hard-On can be recoated with most urethane, acrylic or resin formulated automotive topcoats.
Hard-On by Woolwax™ is an excellent solution for wheel wells which is always a high wash area.
Hard-On™ is a water based coating that can be used on any metal surface. No smell. Paint or spray on.
Woolwax Hard-On is a high performance, permanent 1-time hard shell coating. NOT rubber. For those people that want a "1 time" application, as opposed to an annual maintenance products, Hard-On is a great choice. If you decide to go with Hard-On permanent coating, you will also need a cavity wax for the enclosed protected areas. We highly recommend Creep N' Crawl Cavity wax. This can be found at the the link here: Creep N' Crawl Cavity Wax.
I'm looking into undercoating options, and figured now - with a brand new vehicle and everything pretty pristine underneath - is the best time to get it done. One option I've seen that I see no discussion about in this thread is the Woolwax Hard-On product. Seriously, that's what it's called. Here's the company description:
Any experience or thoughts on this product? Pros and cons? I'm thinking it might be good for protecting against water crossings, salt air and mist from beach driving, etc. The harder dry coating seems better suited to that sort of exposure than a wetter product. I can imagine how easily sand, dirt, dust, and mud will get glommed onto and mixed in with the wet stuff. If you think the Woolwax Hard-On product would be a mistake, please let me know why. Thanks!
Edit - I just thought of one negative, but this would be applicable to the regular Woolwax coating as well as the dry coating, and that is that the helpful torque markings on certain bolts would be covered up. Of course, rust would eventually do that also . . .
If someone was going to Line X their frame I doubt they'd have paid for the powder coating. I figured whatever color it came would get to the same brown eventually, and adding a wax coating would just speed that up.Folks with color powder-coated Grenadier frames may have to consider Line X or other permanent tinted coating.
Did either you or @Tazzieman go ahead with this? I just came back from a trip where I got mud got everywhere (the rear bash plate is pretty much a scoop) so I'm looking at options to make the cleaning process a bit easier.I am planning on giving this a go, the marketing does seem pretty convincing.
I've got some of this to try , plus lanoguardDid either you or @Tazzieman go ahead with this? I just came back from a trip where I got mud got everywhere (the rear bash plate is pretty much a scoop) so I'm looking at options to make the cleaning process a bit easier.
Yeah I took the bash plate off - this was after the pressure wash, mind you!I've got some of this to try , plus lanoguard
If the rear bash plate gets jammed with dried mud I'll probably just remove it for cleaning.
Otherwise just pressure wash - and see what weeds grow on my gravel driveway!
