Coffee said:Thanks for the specs Stu. Has anyone seen payload and fuel capacity?
Also, will North America actually get the diesel?
Paachi said:Payload has always been touted as a metric ton (give or take 50-75 kilos depending upon power plant). Ineos has been pretty serious about that given their aspirations for the Gren as a work truck. So I’d be surprised if it’s anything less than 2000 lbs payload in a non worker slightly glammed up 5 passenger variant.
stickshifter said:First - I'm super excited about this vehicle. I've been dreaming about a vehicle like this for at least ten years. Having said that, I am a little disappointed in three things: (1) no manual option - but the 8-speed ZF is the first auto transmission I have ever thought about purchasing; they drive really well in the Jeep (both the 3.6 petrol and the 3.0 diesel), with crisp shifts, and a knack for always being in the right gear. (2) Given the weight of the vehicle, the petrol engine seems a bit under-powered for a vehicle designed from scratch. (3) It looks like its going to be hard to move up in tire size for two reasons: (a) the wheel wells don't look very large (hard to say), and (b) a bigger spare will block the smaller rear door from opening. I've read their rationale for not offering larger tires (its not a vehicle for off-road enthusiasts, its a utility vehicle for doing hard work), but I think they need to plan for larger tires to be competitive in the North American market. Some models of Jeep Wrangler and Ford Bronco come with 33-inch tires standard, and you can also order both vehicles on 35-inch tires from the factory (with factory-installed gears appropriate for 35-inch tires). Jeep calls this the Recon Package, while Ford calls it the Sasquatch Package. Having a single barn-door in the rear of the Grenadier instead of the split door would have made moving up in tire size much simpler. Making the wheel wells larger gets more complicated...
It would also be nice to get some more specs. I know some things are not finalized, but I'm pretty curious about the following:
1. Axle size, or strength-equivalent (for example, equivalent in strength to a Dana 44 or a Dana 60).
2. Crawl ratio
3. More info on the brakes: Size? Are they fixed or floating calipers? How many pistons?
4. Interior dimensions behind the front seats. I am going to order a 2-seater. The brochure mentions that the interior can hold a Euro Pallet. I assume they mean EUR, or EUR 1, which is 31.50 x 47.24 inches. Still, I'd like to see the actual interior dimensions. I have some long skis that live inside my truck all winter ? I'm spoiled with a 6-foot truck bed, and I'm not a fan of a roof-mounted rocket box.
5. Weight distribution front / rear
Below is a quick comparison between the Grenadier and the 4-Door Jeep Wrangler Rubicon (to the best of my knowledge). While the two vehicles seem quite different in build - the Grenadier seems more of a work/overlanding vehicle, while the Jeep is more of a sport off-roader - but the comparison is relevant because they will be the only two "mid-size" 4x4s with solid (or what Brits call "beam") axles front and rear in the North American market (Oh... I guess we also have the G-Wagon). We also have some full-size pick-up trucks here with solid axles, but those are in another size category entirely.
To see what I meant by "given the weight of the vehicle, the Grenadier seems under-powered" - look at Horsepower per pound of vehicle weight (4.8 in the Grenadier compared to 6.4 in the Jeep). Of course, because its turbo-charged, the Grenadier will make its power and torque at much lower revs than the Jeep, so it will drive much better, but it still strikes me as under-powered for its weight.
Ineos GrenRubicon 4-doorCurb Weight (pounds)58404449Engine 3.0 petrol3.6 PentastarHorsepower281285HP per pound of vehicle weight (*100)4.8126.406Torque (lb-ft)332260Torque per pound of vehicle weight (*100)5.6855.844Wheelbase (inches)115.0118.4Length (inches)194.0188.4Width (inches)76.073.8Height (inches)80.070.8Ground Clearance (inches)10.110.8Turning Circle (feet)44.341.2Turning Radius (feet) 20.4Front Track (inches) 62.9Rear Track (inches) 62.9Tires (metric)265/70/R17285/70/R17Tires (inches)31.6 x 10.432.7 x 11.2Approach / Departure (degrees)35.5 / 36.144 / 37Breakover Angle (degrees) 27.822.6EPA city/hwy (mpg) 17 / 21Weight Front / Rear (%) 55 / 45Alternator 160 ampPayload (pounds)2000892Towing Capacity (pounds)77163500Approximate Base Price$64,400$44,500Let me know if you see anything in here that needs correcting!
PL1 said:Really surprising that Nth. America isn't getting the diesel because a BMW X5D is available and that should satisfy the EPA test. I want a diesel because I want to drive mine to the Arctic ocean and I need the range.
So, a second fuel tank would be a great option, and I'd like to know if a second battery can be fitted.
ChasingOurTrunks said:Thank you for putting together these stats -- it's super interesting and handy to see them side by side!
I think for drivability, the most important number in the torque figures (that will impact how much it feels like it's going to "get up and go") and on that score, I think it's probably about tied with the Jeep based on your numbers. The jeep isn't exactly a race car, but it's fine enough as a daily driver.
I hear you on the tire size thing, and the wheel wells might be a deal breaker for going too much better -- I seem to remember reading they can fit a 35" but I can't find a source so that may not be accurate. And I think the vast majority of people buying Grens will not be putting on larger tires. 33" is about as big as you want to go for Overland travel. Bigger than that is sometimes nice to have off-road, but the majority of the world maxes out at 33" in their off-roaders too, so it's not like 33" will be inadequate, and the typical Overland traveller will accept the compromise; larger tires are much more rolling resistance and unsprung weight, and that doesn't bode well for longevity or comfort. The vehicle is of course a compromise, like everything else - which is why I actually don't mind the split barn door versus the bigger tire argument. You are 100% right that this configuration limits your tire size on the stock carrier (A rear bumper with a swing out is always an option), but I think the number of grenadier buyers who will appreciate the smaller door -- which is essential for rear access in tight spots where there's no room to swing out the big door -- versus those who need bigger than 33" tires will be small. And based on what I'm seeing, most of the folks buying the Sasquatch packages and the Jeep package fall into two categories -- a very small number actually use the car for off-roading, and a very large number simply buy them for looks. I'd prefer the compromise of function over form, personally, and from what I can see the 35" tires are, for most people, a "form" thing.
stickshifter said:Its true - a lot of people go to larger tires for looks alone. I ran 35s on my JKU, and it made all the rocky trails I wanted to drive a stress-free experience, and it makes getting in and out of our cabin much easier in the winter (the road doesn't get plowed every day, and it dumps; but with 35s we always made it in / out). I loved the added ground clearance, and I'm not all that excited about being on a 31-32 inch tire. I run 32s on my Tacoma, and between the added length of the vehicle (compared to my old JKU), and the smaller tire size, we've had to drop some of our old points of access to the back-country. But there are certainly problems associated with moving up to a 35: gearing, braking, added un-sprung weight, added wear & tear on drive train and suspension, etc. I don't wheel my vehicles nearly as hard as a bunch of guys I know here in Colorado, but I do miss having a Jeep on 35s. But for international travel, and for general reliability, I agree: 33-inches is the max tire-size.
Someone posted these photos elsewhere on this forum, but I'll re-post them here. This is a Grenadier on - what might be 35s - in Iceland:
