Hi Does anyone have an issue with the Ineos Tailgate foldable camp table rattle when you go over bumps? If so did you find a fix? I can’t seem to work out what part of it is rattling.
check out https://www.theineosforum.com/threa...nic-table-yet.12413045/page-3#post-1333255687 Post #56 from @SeanHi Does anyone have an issue with the Ineos Tailgate foldable camp table rattle when you go over bumps? If so did you find a fix? I can’t seem to work out what part of it is rattling.
With StorageIf anyone has a link to a good after market tailgate table, i would appreciate it.
Did the same, great (albeit EXPENSIVE) product. I use it all the time for so many things. It’s like a third hand . Highly recommended!I went after market with the offering from @GPFACTOR and couldn’t be happier. It’s a high quality, made in the USA product.
My one drove me nuts, I stuck two large foam sponges in, did not help. I stuck anti rattle tape around the arms and there is no longer any rattle whatsoever. Had never heard of anti rattle tape up to this point. No need to find a different tableIf all the fasteners are tight and there is no play in the closed position. Then the next step is to use black anti rattle felt tape on certain inner sections of the arms which rattle against the table on bumps.
I have no rattles from my camping table even when off roading.
Can you post a picture of the table with the tape visible around the arms, thanks.My one drove me nuts, I stuck two large foam sponges in, did not help. I stuck anti rattle tape around the arms and there is no longer any rattle whatsoever. Had never heard of anti rattle tape up to this point. No need to find a different table
Anti rattle tape is what dealers use. I’ve used it in all situations, from behind gloves boxes to and door trims to fix rattles.My one drove me nuts, I stuck two large foam sponges in, did not help. I stuck anti rattle tape around the arms and there is no longer any rattle whatsoever. Had never heard of anti rattle tape up to this point. No need to find a different table
Thanks Dennis, Sean’s solution of swapping the top spacers with the bottom ones worked for me.check out https://www.theineosforum.com/threa...nic-table-yet.12413045/page-3#post-1333255687 Post #56 from @Sean
and
Post #20 by @Skiprat here: https://www.theineosforum.com/threa...ir-picnic-table-yet.12413045/#post-1333226008
