Hi grnamin, That is a nice video showing the differences. I would say the Fox Steering Stabilizer is a
significant improvement. Would love to get you input on how it performs off road. DaBull
Thank you, @DaBull. I'm planning on a day trip to a nearby OHV park in the near future.Hi grnamin, That is a nice video showing the differences. I would say the Fox Steering Stabilizer is a
Quite frankly, I didn't want to risk driving without a stabilizer.@grnamin, any chance you took it for a spin with no stabilizer?
I was just at the dealer two days ago for a test drive. Drove the stock vehicle, with the stock steering. I thought it was fine, a little annoying at first, but not much different from other vehicles I've driven. I'd get used to it... but I also drove one that the dealer told me had an Old Man Emu steering stabilizer installed. It was much nicer, returned to center was much improved and I felt I could drive it single handed, if I had to. It was just a short test drive, but just based on that experience it's now high on my list of "mods". Not that I really absolutely dislike the default steering, but the Emu stabilizer felt more like what I was expecting (coming from a Wrangler JK). Have no idea how it behaves off road. The dealer did mention that they've also installed Fox stabilizers, but he thought the Emu one was the better of the two.
Crap - was traveling all week, and you mean to tell me you got this done without me??? Your Grenadier will probably explode in a couple weeks. This looks pretty good - can you remind us which Fox bar you got? I don’t know if it was the adjustable one or not - one is 2something, one is 5something.
I'm not sure if everyone's Grenadier has both nuts welded in. The Agile instructions stated that the passenger side nut required just one 18mm socket wrench and the driver's side needed two 21mm sockets. I only needed one socket for the latter. The instructions also said that the driver's side bracket might need to be spread apart to accommodate the stabilizer and two washers. In my case, they fit loosely. Each bolt has a different torque spec in the instructions. It's easier to install the driver's side stabilizer end first since you'll need to align the bolt through 2 washers and the nut on the other end of the bracket. I compressed the stabilizer by hand to align the passenger side end to the nut. Instructions say to turn the steering wheel one way to align the bolt. Hope those help.So give me a couple tips - use a longer arm socket wrench, and the nuts are welded in, so only worry about the bolts and washers - is that it? Anything else? I’m taking off for Germany this weekend, so figure it will be a couple of weeks before I get to this - depending on how long it takes Agile to get it to me.
No, this doesn't alter anything that would change the alignmentAlignment required?
I emailed him for details, but haven't heard back.Did the dealer mention how they were sourcing the Old Man Emu stabilizer? Any chance they are selling them thru their parts department?
I removed my steering stabilizer today.
I kept reading expecting a punchline, but it was all true!I removed my steering stabilizer today.
WOW!! What a difference!
Steering returns to center like most every other vehicle. Low-speed turning of the wheel is MUCH quicker. Three point turns greatly improved. The ability to go quickly lock to lock makes the turning circle feel smaller.
No problem steering with only one hand in parking lots and driveways. One hand steering while pulling out onto a perpendicular street, without fear of ending up on the sidewalk.
Highway tracking is improved as well, but not nearly as much improvement as low-speed.
Death wobble...
Rock solid at speeds up to 65-70 mph.
I hit a large seam in the pavement at 75-80, though and could feel it want to shimmy.
The steering wheel began quick oscillations that reduced in amplitude over a second or so until gone.
This leads me to believe that there is some static instability in the steering system, but that there is positive dynamic stability.
In summary, I'll never put the INEOS steering stabilizer back on!
I will, however; keep my speed down until I can get an OME or Fox stabilizer installed.
Really? If true, I won't say I told you so. I'm surprised there's even a shimmy with stock tires. Maybe do an adjustable unit and tune it as low as possible.I removed my steering stabilizer today.
Death wobble...
