- Local time
- 8:34 AM
- Joined
- Sep 25, 2021
- Messages
- 407
The 80 psi rating would also explain the need for steel-not rubber-valve stems on the wheels. Indeed, the 17” BFG would seem to be the ‘stronger’ tire.The max pressure and load rating of the 17” bfg is 3195 lbs at 80 psig while the 18” bfg is 2835 lbs at 65 psig. I believe the 17” version of this tire has additional plys in it’s construction. This info is from tire photos at the Colorado event last week.
