- Local time
- 11:50 PM
- Joined
- Aug 24, 2022
- Messages
- 2,447
INEOS has used steel valve stems (thanks @Jean Mercier for the picture) to reduce the risk of damage to them when spinning in mud and sand etc. In theory this sounds like a good idea. But I do wonder whether it’s actually true? I wonder in fact if a rigid stem is actually more likely to get bent or damaged than rubber or plastic as it has no give, whereas a more flexible one might bend as you brush past an obstacle and return once past?
