Springs in the Quartermaster
ADVAW8S
Global Grenadier 0044
Quartermaster Owner
8:24 PM
WA, USA
Need some help from the hive. Do you think or can someone with close ties to Ineos answer this question. @anand @Stu_Barnes @Krabby @AWo @MossyIG @Mossy Ineos Grenadier TX
Does the pick up truck use the same springs as the SW or are they different? I am asking because Airbag man is asking for dimensions to see if they have a system in place already for quartermaster. Then also if they are than my new Eibach springs will work and I will need to get them the dimensions.
I did ask my dealer and they said they can't answer till I arrives in states.
I'm 99.9% positive they will use different spring rates than the SW, but for actual spring diameter, it would seem logical to use the same inner and outer diameter.
With that being said, aren't they in Oz where the QM is available currently??
Reactions: Max
Yes but I don't think they have addressed the eibach lift yet.
Ahhh I missed that part... I would say the Eibach springs (assuming US spec) will not be appropriate for a QM, especially if you are adding any weight to the rear; on a SW with mild weight added (an empty Buzz Overland drawer system and empty fridge) to the rear they squat quite noticeably and given that the QM has a lot more length behind the rear axle, this will contribute even more to that effect
The stretched wheelbase will also mean the vehicle sits very differently on the road so I would be very confident the front and rear springs will be totally different to the SW
Reactions: Max
Sounds good, so I'll have to put my springs for SW up for sale and wait for what is developed for the QM. Plus wait for airbag man.
Spoke to a guy who saw one in UK. He said he was seeing green circles and red triangles on the QM.
@Stu_Barnes is the labeling backwards. I was looking at the excel sheet and the one pager that was shared with us showing the part number and color coded symbol. The 19550 is listed as front but the sheet shows it as a progressive spring which I would suspect would not be used in the front. It looks like the picture listed as the rear is a spring rate we have not seen before 19548.
It also looks like they may be using the same springs as the SW. Because the rear is blue circles which correlates to the blue circles on the sheet.
You’re right. It’s corrected now.
