SOUND SYSTEM EQUALIZER TUNING FOR THE GRENADIER
DaBull
10:19 PM
California
I am no stereo or sound system expert other than knowing what I like to hear.
I have found the existing Grenadier sound system including speakers to produce very nice sound/music, however it sounded a bit flat. I went to the equalizer settings and tuned it to my liking, which as you will see is 77444. The first 2 numbers have to do with low and medium base settings and the next three numbers have to do with higher notes. I like listening to a lot of jazz, smooth jazz and surf music.
I like equalizer settings that are tilted a bit towards hearing higher notes and treble, as I like the crispness and clarity that it provides. I also like a bit of bass, however not too much. My Trialmaster has the dual batteries and no sub-woofer, (which from what everyone says is underwhelming anyway). I may add a sub-woofer in the future, especially if it is a pure plug and play set up.
I currently own a 2020 New Defender with a Meridian Sound System with 10 speakers, 1 sub-woofer and a 400W amplifier, which sounds great. After tweaking my Grenadier equalizer settings to 77444, the sound is equal too or perhaps better in my Grenadier than in my 2020 New Defender.
Instructions are further below on how to navigate to the Equalizer to set up your own custom preset. Note: Like many have found, navigating to the same setting screen does not always follow the exact same steps each time, it’s just part of the Grenadier experience.
When you get to the Equalizer Setting Screen, you will see it has 5 settings, going from left to right. The first two are for low and medium base sounds and are labeled 63HZ & 400HZ. The next three are for higher notes and are labeled 1KHz, 2.5KHz & 6.3KHz.
Everyone has their own preferences for their listening pleasure. My custom equalizer setting is currently 77444, which sounds exceptional to me.
I tried higher settings for the upper range by setting it at 77555, 77666 and 77777. For me, the higher upper range settings were nice at first, however after living with them for a while, they were too high. In preparing to tweak the equalizer settings, I did some research and read that having the upper range too high can sound good at first, however it can also be tiring on longer trips. I imagine it is the same with base.
The limited information I gathered in setting up an equalizer was to first set the volume up to one step higher then you are likely to listen too it. Next add additional base until you start to hear a little distortion and then back off one step. This is how I ended up with the first two numbers being set to 77. Note: When tuning the base, you should do this while the higher notes are neutral or flat, which would be setting them to 0 or 1 initially.
After tuning the base numbers to be 77, I then raised the higher notes up to add more crispness and clarity to the sound and found out I liked 444 for the last three settings.
Once I got this all dialed in, the difference in how the music sounded from the stock settings was a world of difference for me. Before tuning the equalizer, the music on all of the Grenadier presets, (which are flat, pop, rock, jazz, classical & news), sounded a bit flat and muffled. After tuning the equalizer to 77444 the sound was exceptional with more depth and clarity. Although I will likely add a sub-woofer in the future, would I consider adding new speakers, amplifier and equalizer? Not so sure anymore. I would first have to hear the difference in person and then make sure it is a plug and play installation and worth all the extra money. In the meantime I am extremely happy with the sound in my Grenadier at my custom setting of 77444.
Note: I did not change the Fader/Balance setting as after playing with them I liked the factory settings best.
Now it’s your time to unleash your own sound/music preferences. Here’s how to navigate to the equalizer setting, adjust them and save it as your own custom setting on the Grenadier. As mentioned before, navigating to the Equalizer Setting Screen may be different for your Grenadier.
1 - Go to Main Home Menu Screen.
2 – Press Settings below Home.
3 – Press Acoustic Settings.
4 – Press Equalizer.
5 - On the right where it shows Flat, Pop, Rock, Jazz, Classical & News Scroll the screen up until you can see Equalizer.
6 – Press Equalizer.
7 – Adjust the 5 Equalizer settings to your preference by touching each one and moving them up and down.
8- Press Save As Custom
Note: You can only save 1 custom setting, however you can change it as many times as you like.
Enjoy! DaBull
Hah I was just going to start a thread on this, thank you for bringing something to light that many have not talked about!
A vastly different setting for me with stock speakers... 14,9,3,4,4. Apparently, I prefer much more bass :P
More on these settings in a post I'll be making shortly for my swap to new door speakers
I didn't want to be the one to post this, but this was the first thing I thought of when I saw @Tazzieman 's post... I am not too proud to admit that I had this on my Mk4 GTI back in high school
My wife is now the one warning passengers about the neck snapping g forces in her Volvo.
20 years ago I would have laughed out loud.
Now , recovering from a broken neck...
Question: has anyone tried to turn up the volume past 10? When I hit 11 or higher, the EQ kicks off and the sound is flat. It's terrible Am I the only one with this problem?
I've spent plenty of time above 10, no issues with sound, but then again, I'm also on different speakers and an added sub
I have two EQ changes that occur with my stereo.
Upping the volume from 8 to 9 completely changes the EQ sound and it sounds like an additional 6dB of mid at 1k Hz is added into the mix. This doesn't always occur at the 8 to 9 notch, but usually occurs somewhere in the area of 6 to 9 with a single increase in volume input.
The second EQ change occurs with the shift from part to reverse. Doesn't always happen, but when it does, the sound goes from a flat sounding setting to my preset.
I have this one.... Almost sounds like it goes up 1 click in volume.... Which is odd because many other vehicles decrease the volume in reverse
Enjoy! DaBull
Found this older post and did what you said, but when I get to the Equalizer it is a lighter shade than the other choices and it won’t let me enter the Equalizer option. Any idea what I may be doing wrong? I have the dual batter my no upgraded stereo, but seems you have the same options and can enter and change the Equalizer settings. 🤷‍♂️
DaBull~
Thank you for the detailed help on this post! I was able to adjust - but it is STILL way too "bass" heavy for my liking.
I have the premium sound - and unsure if its due to the subwoofer or not. Might need some recommendations to be less "thump" when playing loud(er).
Thanks again!
~Skip
DaBull~
Thanks again!
~Skip
Can’t you turn down the gain control on the subwoofer itself.
After reading this thread, I had the idea that if I was to take my EQ settings and drop them as low as possible (ie: whatever my lowest level was, drop that to -14 and set the rest proportionally above that level) then this would alleviate the problem of the volume gradations being too coarse.
I am happy to report that it works!
Now I have much finer control of the sound levels at low volume. Normal listening is 6-7 instead of 2-3.
I suppose I give up some maximum sound level at full volume, but I'm OK with that.
I don't "crank it up" like I used to.
Have to select custom first then equaliser will be illuminated and you can select it and follow instructions in the thread
Thank you for sharing your EQ settings, will try them!
The thing i found annoying about the sound is that the volume steps seem to be to large. I am usually at 2, but 1 is to quiet and 3 is to loud sometimes at low speeds. So it would be nice to turn down the total volume a bit, to have more room to play with the volume controls. I already turned off the 'Speed Dependent Volume Control', which seems to make the steps even larger at higher speeds.
Also the settings 'volume at start' doesn't seem to work? I set it at 2, but doesn't seem to do anything.
Any ideas?
