Q&A Americas Something Ineos Should Investigate Regarding Vibration Issue
DaBull
6:15 PM
California
Hi Ineos, There has been a lot of Grenadier owners experiencing vibrations in the drive train that is felt in the vehicle and through the steering wheel. I owned a Range Rover Sport with the exact same issue and Land Rover was able to cure it by installing a damper that they had left off. They even issued a technical bulletin. regarding it. Perhaps you could escalate this up to the engineers at Ineos who are trying to deal with the vibration issue and see if this is something that might work and cure or eliminate this issue. It 100% cured a very similar if not exact same type vibration issue I was having in my Range Rover Sport. It's worth a look.
Here's the link to read regarding the damper issue and view their technical bulletin showing what it is and where it was installed.
https://static.nhtsa.gov/odi/tsbs/2013/MC-10214006-9999.pdf
I wrote exactly what you wrote to INEOS months ago. Unfortunately, I have not heard back. Too bad!
