Software Update for Fuel Plausibility - US MY24.1 only
TSB Software Update for Fuel Plausibility - US MY24.1 only IATSB003368 v2
No permission to download
Stu_Barnes
Fixer & General Dogsbody
12:44 PM
Los Angeles
Stu_Barnes submitted a new resource:
Software Update for Fuel Plausibility - US MY24.1 only IATSB003368 - Refueling check engine light fix
The attached TSB describes the Software Update for Fuel Plausibility- US MY24.1 only.
Click on the download button for more details.
Issue: An issue has been identified on a small percentage of the affected vehicles where the Engine Management Light turns on after the vehicle has been re-fuelled.
Cause: The actual fuel level is not available within the specified time frame from DME for leakage detection.
This results in a fuel level un-plausibility after refuelling and puts an...
Read more about this resource...
Good to know. Mine was updated in Oct and it's been fine, but I got a fresh CEL last week on fill up. Same code. Guess I'll contact the dealer. (12/23 build date)
Very concerning when a TSB contains such words as un-plausibility (wrong spelling too).
That type of IT BS has no place in a vehicle workshop.
Sorry. OBD? I would like to clear my similar happening. Process? Thanks in advance.
OBD2 Scanner... the OBDLink MX+ is a commonly used one
Happened for the first time for me yesterday. Does it stop happening after the software update? If it doesn't stop from the update being installed, I will just keep resetting it with my OBD.
The TSB for MY24.1 vehicles exhibiting the code should stop it from happening
Hi all- related issue im tagging here- the CEL came on after refueling. Happened to be on a road trip and noticed the cruise control was INOP with light on- related or coincidence?
It is related - clear the CEL (with OBD) and cruise will come back on.
Also note, this happens to me every other fill up, so purchased a OBD to clear each time. Was in to Elliot Bay (Seattle dealer) for new windshield, key spring broken warranty replacement, 12k service and door button warranty work this week and they would not update my software as the CEL was not on. So…if headed to EBA, stop by the gas station first to set off the CEL so you can get the update if you need it.
Thanks 312’
Learned a couple of things today. My ‘24 does not qualify for this TSB, but there may be another update to address this. No eta that I’ve been told
Second thing i learned is that IF the CEL is on AND the Refuel Soon warning is on- and you actually refuel - the CEL goes out. YMMV. But I’ll have to see if this is repeatable if it comes on again. That said, the cruise control is still inop with the CEL off
The mysteries continue….🤣
