Is that what it gives you when you search your VIN or when you try to check out?
When you check out.Is that what it gives you when you search your VIN or when you try to check out?
Thanks for the effort. I did not realize it cost money! I'll poke around and see if I can find a free one.It generates a sticker for me but I can't see it without paying 10 bucks. Ineos isn't in their brand list but just plugging in the VIN it reads as an Ineos.
What did it show you?
I believe over 6000 lbs is exempt from a regional transit tax which is calculated based on vehicle value every year. If exempt I think it would save me over $500 a year on my tabs.Interesting! Shows the vehicle as class 2F - 7001-8000 pounds. Wonder if that affects our registrations.
This is what I get based on my VIN. Not sure it's totally accurate, because wouldn't this be considered a 6 door vehicle vs. a 5-door? Also, interesting that it shows Adaptive Cruise Control + Keyless Ignition + Blind Spot Intervention.What did it show you?
I saw that - but there's no indication of whether that stuff is there or just listed.This is what I get based on my VIN. Not sure it's totally accurate, because wouldn't this be considered a 6 door vehicle vs. a 5-door? Also, interesting that it shows Adaptive Cruise Control + Keyless Ignition + Blind Spot Intervention.
Mine is 0564I received a VIN from my dealer and was told build month was 8/2023. They're expecting delivery late November or December. Last 4 of my VIN are 7069.
You sure that is correct as a VIN? I suspect the 0 is not right.Mine is 0564
I would suspect if you check the last 5, it is 10564You sure that is correct as a VIN? I suspect the 0 is not right.
Good to see the VINs now into the 10,000+ range, first one I've seen quoted on the Forum.I would suspect if you check the last 5, it is 10564
I need to give them the year and make of my vehicle before I can research my serial number. There's no mention of INEOS as a make on their site, so I can not enter my serial number. I think it is too early to expect that level of detail.
Last 5 are 00564. I signed up Sep 30, 2021 don’t know if that matters.I would suspect if you check the last 5, it is 10564
Last 5 is 7320
