Rubber mount / bumper placement
khmarks
7:05 PM
Raleigh, NC, USA
Received my Grenadier 12/20/23. Had a rubber piece fall out the back a day later... attached is a picture of it. Can't figure out where it goes. Anyone help?
Rear right door. Prevents damage in case you close the left one first.
Refit with a larger washer.
If you search you will find many other threads discussing the same part. :)
View attachment 7837655View attachment 7837656
Hi Khmarks, That is one of two bumbers that go on one of the rear doors to make sure one door closes before the other. The cure is to put a large washer on before the screw that holds it. The screw should still be in the door. Many have taken a large washer and then ground it down or cut it to have a squarer profile in order to give as much coverage of the rubber area so it will not pop off again. Something everyone is dealing with. DaBull
