Roof Outlets stopped working
4:42 PM
USA
External Roof outlet power stopped working. Interior control Switches for Exterior outlets illuminate including Power switch. Checked fuse 128 -ok. Checked all other 5-25 amp fuses-all ok. Thanks for the assistance!
Do you mean the fuses in the High Load Auxiliary Switch fuse box?
Both rooftop 25 amps circuits or only one? If one, which one.
Also check Item 4 below, which powers the High Load Auxiliary Switch fuse box. 80 amp fuse may be blown or the cable might be loose.
5 STUD BUSBAR*
From left (1) to right (5) the amp ratings of the ZCASE®MEGA fuses are:
  1. SHUNT power from the Pre fuse box interior (comes from Stud 7 on the 7 Stud busbar);
  2. 300 amp for the CTEK SMARTPASS120S and AUX air compressor (in AU spec);
  3. 350 amp for the Rear NATO plug Relay;
  4. 80 amp for the Fuse Box for the High Load Auxiliary Switch Panel option; and
  5. Spare, no fuse or stud supplied.
5-stud-busbar-au-dxo-jpg.7843522
Busbar from AU Spec diesel model.
Your reply fixed the problem. I was unaware of this fuse location as its location action is hidden by a screw down plastic shield over the main battery. Large star drive bolts are hard to remove as seat assembly obstructs back 2 bolts. Mahalo as we say around here!!:)
Some other mysteries are revealed by these links:
PLACE TO START FOR NEW OWNERS
  1. Download and use the Rok Dr Guide here. Print out a copy and keep it in the car;
  2. Grenadier Accessories (huge selection) for you to buy here;
  3. Kanvas bags and products here;
  4. Information concerning Deutsch DTP plugs here;
  5. Learn more about the CTEK SMARTPASS 120S and 250SE here;
  6. Fuse and relay thread here;
  7. Suggested Grenadier or QM fuses spares kit here;
  8. Littelfuse FHZ busbars used in the Grenadier here. It also informs you where all the busbar cables go;
  9. Finding the aux power outlets in the footwells here;
  10. Table describing all the available wire ends here and here (more wire ends if you selected the high aux power option);
  11. Various recommended torque settings here;
  12. Tool kits for the Grenadier/QM discussed here and here;
  13. L track information here;
  14. Oil filter part numbers and third party filters here;
  15. INEOS Air filter parts numbers and cabin filter here;
  16. Filter for Diesel water separator here;
  17. Understanding the NATO plug on the Grenadier here;
  18. What do you use on bolts/screws to stop corrosion, galling and seizing here;
  19. Guide to terminal crimping here;
  20. Anderson plug pitfalls here;
  21. Outback driving tips here; and
  22. Cheap battery monitors here.
