Here you go ~ at what vehicle weight do you measure it?Please let’s reignite the “what constitutes ground clearance?” debate: it’s been at least a few weeks.![]()
That diff looks pretTy robust and well guarded. Is that a bolt on guard /outer cover ?One at the front, one at the back, one for the fuel tank, various cross members, one for the sump(?) and perhaps guards on both diffs.
If you don't , sod's law says you will hit something as you drive away from the agent.Having said that it looks great and I'll probably get it anyway.![]()
I was 'betwixt and between' on this ---wife had no issues when we went for the drive day, however on a visit to the Brisbane agent's showroom it was evident that the side steps were very useful when 'negotiating' one's way to/from the vehicle where door opening was restricted... so they're confirmed on the order....The Ineos is the same height as my lifted Disco ; no probs for my wife (5 ft 6) or myself to get in without steps.
But as always try before you buy.
Justin Hocevar pointed out that as the vehicle is so wide in normal carparks it is often difficult to swing the door wide enough to get out easily.The Ineos is the same height as my lifted Disco ; no probs for my wife (5 ft 6) or myself to get in without steps.
They are also handy when strapping things on the roofI was 'betwixt and between' on this ---wife had no issues when we went for the drive day, however on a visit to the Brisbane agent's showroom it was evident that the side steps were very useful when 'negotiating' one's way to/from the vehicle where door opening was restricted... so they're confirmed on the order....
Then I thought of another use for the side steps... as a base for self supporting slanted awning poles![]()
I don’t think they reduce clearance significantly at all from the look I had.Although not configuring with roo-bar, am considering rock sliders (for benefit of protection vs cost of weight). Is there any reduction in either or both of clearance or ramp-over? My use will be on forestry fire-trails and national parks roads, on farm use as well as overlanding eventually.
Thanks in advance!
I avoid carparks wherever possible!Justin Hocevar pointed out that as the vehicle is so wide in normal carparks it is often difficult to swing the door wide enough to get out easily.
He said he stands on the step then closes the door and gets down.
I thought that was "Murphy's Law"If you don't , sod's law says you will hit something as you drive away from the agent.
And it may be a while before the aftermarket chips in with its expensive alternative .
I imagine it has been rigorously tested anyway.
Murphy identifies as Sod now.I thought that was "Murphy's Law"
Fraid I'm not from Aus so thankfully don't have the problem of roos over here....I saw the roo bar last week. I'm unclear how many actual roos have been part of the testing. I'm pretty sure if you nail a decent one it will bend back and hit the body work.
I'm also concerned about whether you'll be able to straighten it by hooking up a big rope to a tree and persuading it back. Might be a problem if you hit two on a trip.
No badger bars either?It's a shame roo bars (we call them bull bars even though we rarely have bulls jumping out in front of us) are banned in the UK![]()
