Reverse Camera manual turn on.
and1939
1:52 AM
Windermere, FL, USA
Does anyone know a way to manually turn on the reverse camera. When I tow with some of my other vehicles you can turn on the reverse camera to see what's going on.
I know I could manually add a camera and screen but would prefer not to.
This hasn't been figured out (or, more accurately, deeply looked int) as of yet by anyone.
I know some Toyota products allow simple activation by the addition of a switch across several terminals of the head unit wiring, but other European vehicles require a module to reprogram the headunit to allow this. Which way it will work with the Grenadier remains to be seen
Except if the camera is started by a CAN bus signal. 🤷‍♂️
Thanks. That sounds like the way to go and then just add additional cameras for under neath side etc. I plan on putting my Rhino rack on as soon as the mounting brackets come in. It would be cool to have 360 camera up top as well.
When off-road mode is engaged, we get the option to switch on the camera.
It would be good if this option was available all the time. 🙂
