Retrofit Interior Utility rails
Gerritvr4
2:17 AM
Perth WA, Australia
Does anyone have a link to aftermarket L-track suppliers (Australia preferred). I've picked up from the different forum threads that you get different sizes and not sure which ones are compatible or rather the same size as what Ineos uses. I am in the process of purchasing a drawer system that uses the INEOS utility rails, but I didn't order them with the car, so want to make sure I buy the correct Track.
L Track can be purchased here. Cut it to size (if needed). AU source, competitive pricing.
Multiple links here for sources around the world.
Most of the third party suppliers quick releases tie downs work on the Grenadier. INEOS used standard L track size.
Wow, that heavy grade Aircraft L Track costs a lot more than our standard grade, over AUD900 for 3.66m.
Can you order the parts from the dealership? I didn't get the tracks as well, but have thought about adding them in the future.
I just took mine out to install drawers. Haven't made a classified ad yet but DM me if you want to talk.
Can’t be retofitted easily as the factory fit interior rails are held by three studs. The non utility rail versions have 2 pre drilled holes.
I assume the 3rd hole is just under the floor mat.
Correct. Someone’s posted photos. I’ll see if I can find it.
Found:
Post in thread 'Installed my boot rubber mat'
https://www.theineosforum.com/threads/installed-my-boot-rubber-mat.12412935/post-1333256638
If someone measures the holes we can compare them to the factory track but I really doubt Ineos would take the time to drill different holes in different bodies when they can just plug a hole with a bolt like in the photo I linked.
Found:
I just took a look at mine, looks like all the holes are there? I was assured by Ineos chat that I could add the tracks later if I wanted to, for what it's worth.
Thanks @MTNDOG. That picture is better. In the vehicles with track, the inner holes on the rings are taped over. I had to open them to install my drawers.
Yes, you can, but they are ridiculously expensive.
For Australian users these maybe able to be fitted, for example, on top of any drawer (on the adjoining sides, not the drawer itself). RV Storage Solutions, look here. The INEOS L tracks are 750mm, these are 600mm.
Here are my INEOS tracks moved to the drawer sides.
full
full
Just got done fitting OEM cargo rails to my IG which didnt originally have them. Super simple, started by using a razor blade to cut the nubbins hiding the middle bolts in the cargo liner, then remove the standard OEM tie down points, used 4 black plastci plugs to fill the holes in the floor that are not used, then installed the rails with three bolts per side.
Where did you order the OEM rails? When I got my truck I asked and the price seemed much much higher than worth it.
Mine will be up for sale within the month, as soon as the material gets here to build my drawers
I thought aluminum replacement rails either raw, brushed or anodized matte black would've been then first thing a Chinese manufacturer would have thrown up on AliBaba. But no, they went straight for molle plates and auto steps! (I’m talking to you Summer Auto 😉)
Just to refresh this thread. Has anyone come up with a good way to retrofit the Interior Utility Rails into a Grenadier that didn’t have them from the factory? INEOS makes it prohibitively expensive for what you get and also more complicated than necessary.
Jay
