Refuel Now
IMPRMNS
3:19 PM
Massachusetts
Hi all,
It appears that others have experienced the following situation and I'm hoping there is a DIY fix rather than a dealer visit.
I have a full tank of fuel (not topped off and I've driven 30 miles or so since refueling) but I am greeted with a rather obnoxious audile warning upon startup with a message to "refuel now." My fuel gauge reads close to full. Anyone have this issue and have found an active solution? Thanks in advance.
Hi all,
Press and hold the mute button until the screen goes completely black, not just the radio side the entire screen, than release. The Ineos startup screen should appear. Do this running but stationary.
I didn't get to try this as I changed my oil and when I ran the measurement test, it cleared the issue. I will, however, try it if (when?) it happens again. Thanks!
Hi all,
Predictive analytics. It knows you have a lead foot :)
My dealer told me that might happen but and to do the following. when you pull up to the pump and turn the key off just turn it back on (not to start) and then fill up.
I'm waiting for one of these dealers to tell me that all I have to do to fix the next problem is to push Up, Up, Down, Down, Left, Right, Left, Right, B, A, and Start.
Contra!
I have that happen parked nose down on steep driveway or hill. It should resent next time on level ground with engine off for more than 10 minutes or so..
