has anyone had the problem of not being able to open rear doors? I have had the occasional problem of not being able to open rear doors. Would randomly happen. Unfortunately it has been 2 weeks now since i have been able to open the main doors.
That was my occurrence, where the button did not engage the actual opening mechanism when the ‘unlock’ (all doors) command was given. When I began to operate the interior handle I heard a “click” as the outside button re-engaged. This has occurred twice.Have you tried from the inside? I remember someone posted at one point saying the button had become detached from the mechanism
There is something going on, when I close the door with force it's hard to open but if just push it shut softly, no issue at all Stu_BarnesMine definitely feels a bit grindy, and it takes a lot more force than the other to open, is there any noticeable sagging on your doors or misalignment @Max ? I know there have been a few with slightly misaligned rear doors in the USA.
Problem is i have draw system fitted and can’t get to the inside handle.Have you tried from the inside? I remember someone posted at one point saying the button had become detached from the mechanism
Ah, we appear to have the same problem @Murray2105 . What did you end up doing?Problem is i have draw system fitted and can’t get to the inside handle.
Indeed, this is loosely equivalent to my own idea. We have the additional problem of the loadspace being filled with luggage and a cargo barrier in the way. Our drawer system is almost snug against the rear door so it will be interesting to see if the manual latch can be activated without modifications to the drawer installation.I've just tried a small experiment:
With assistance of the faithful co-driver in the driver's seat, I sat in the rear compartment, pulled both doors shut and co-driver locked the doors with the switch on the driver's door. The handle on the "30%" door needs to be pulled twice (like the bonnet /hood handle) to free the latch.
I shut both doors firmly then locked the car with the remote. Again, the "30%" door latch released on the second pull and opened without the alarm activating!
So, have established that the mechanical act of operating the internal door handle overrides the solenoid locking mechanism
My first thought for a solution is to obtain a 1.5m length (or there abouts) of 1/2" plastic conduit and thread it with cord or thin wire with a "noose" protruding from the end to snare the handle. Approach the door from the back seat over / between whatever might be in the way, if possible and "fish" for the handle with the noose dangling from the conduit. Once over the handle tighten the noose and pull the door handle..twice... that's the theory...as for practice...Thin wire instead of the cord at least would enable one to manipulate the noose into position more effectively to snare the handle.
The fact that @Murray2105 couldn't hear the lock deactivating implies it's either the solenoid itself, or a perhaps plug has come loose or a fuse has failed. I wondered if each door solenoid is separately fused, possibly not, with a single fuse for the system.
The answer to this just might live under the rear seats...a circuit diagram would be handy! (HINT for any IA sleuths perusing this forum!!! we're still waiting!) The dealer might be kind enough to email you the necessary info... that was the advice from Ineos Australia /Asia Pacific CEO Justin Hocevar at the tech talk in Brisbane last year.
First things first ...get the door open...
Ah yes, same symptom. Our battery was down to 67% after two weeks in a container so I’m also wondering if that’s a factor. Please keep us updated and we’ll do likewise.I haven’t done anything yet. Have to try and remove everything to access inside handle. I can’t hear the lock operating when unlocking with the remote.
So they are not disconnecting your batteries for shipping ?Ah yes, same symptom. Our battery was down to 67% after two weeks in a container so I’m also wondering if that’s a factor. Please keep us updated and we’ll do likewise.
I left it connected as it was only meant to be a three day container transit (two weeks later…) and we were racing the clock.So they are not disconnecting your batteries for shipping ?
