General Rattle noise after cool morning start
LAdrummer
3:01 PM
Los Angeles, CA, USA
Does anybody know what this rattling/tapping sound is and should I be concerned? Thanks in advance.
  • IMG_2545.MOV
    1.2 MB
rovie
6:01 PM
Does anybody know what this rattling sound is and should I be concerned? Thanks in advance.
Can you explain this in more detail? In the engine compartment, under the vehicle, inside?
Vote:
Upvote 0
rovie
6:01 PM
Sorry, I thought my video was uploaded. here it is.
To me it sounds like vibration of an add-on part, loose sheet metal, etc. From my point of view, this is not coming from the engine. Take the plastic cover off and touch various components with your hand while the engine is running.
By the way, the video is now also displayed in your first message. For whatever reason, this was delayed.
Vote:
Upvote 0
LAdrummer
3:01 PM
Thank you Rovie. I’ll take the cover off and investigate as you recommended. I’m pretty sure it’s internal (engine tapping).
Vote:
Upvote 0
MTNDOG
3:01 PM
PNW #359
Is the turbo down there? The waste gate actuator rod on my F150 used to rattle like that, I will check mine out after a bit and see if I get any similar noise when I start up my Ineos.
Vote:
Upvote 0
rovie
6:01 PM
Does the noise disappear when the engine is warm?
Vote:
Upvote 0
LAdrummer
3:01 PM
the dealership had their shop foreman sent me a video of a new vehicle. evidently, they said it is normal. could not upload the video here "video too large"
Vote:
Upvote 0
C-Mack
4:01 PM
Logan, Utah, USA
If it is loudest in the back left corner of the engine compartment as you are standing in front of the vehicle that is where the High Pressure Fuel Pump is located for the direct injection system which sits on top of the valve cover on the petrol powered models. It operates at well over 300 bar in pressure and can be quite noisy especially after engine start and during cold idle. It should quiet down as the vehicle warms up but you’ll always hear some amount of clicking/tapping coming from it and the associated rigid fuel lines routed across the top of the engine.
Most direct injection engines have similar noises and when I first got my Grenny it really stood out to me. I have other direct injection vehicles with similar fuel system sounds but by far the B58 as it is installed in the Grenny is a bit louder than most to my ear.
Vote:
Upvote 0
