Diesel Question about loose part on B57 diesel engine during cleaning
explorersoverland
7:25 AM
Netherlands
Hi everyone,
I’m currently preparing my Grenadier for shipment from Surabaya, Indonesia, to Perth, Australia. As part of the process, everything needs to be super clean to meet Australian customs requirements.
While working at a professional cleaning company, we discovered a part on the B57 diesel engine that seems to be loose. The team isn’t sure if it was already loose before cleaning or if something happened during the process. It also doesn’t easily go back into place, even though it looks like it should. A similar part in another location seems to be securely attached.
Could anyone help identify what this part might be? Does it also appear loose on your Grenadier, or is it supposed to be fixed in place?
Thanks in advance for your insights!
Kind regards
Alexander
@explorersoverland
C-Mack
11:25 PM
Logan, Utah, USA
It’s a ball and socket fitment… the female end has been fractured and is the reason why it won’t stay attached. It’s supposed to attach in the same manner as the actuator directly opposite of it. You’ll need a new part by the looks of it.
explorersoverland
7:25 AM
Netherlands
Wow you’re right. I didn’t even see that before!
Do you know what it is for? Can I drive without being connected?
C-Mack
11:25 PM
Logan, Utah, USA
I’m no expert on the B57 diesel engine but I believe that is part of the Exhaust Gas Cooler or EGR system. For the vehicle to run efficiently you’ll need both actuators to work or it’ll probably create a check engine or emissions warning light. I wouldn’t drive it very far unless you had to without getting it checked.
If it’s an emergency situation you might be able to put the plastic arm back into position and wrap some fine gauge wire or a plastic zip-tie around both parts to try and hold them together. Other than that, I’ll let someone else on the forum who is more familiar with the diesel version provide better advice but for sure it needs to be fixed.
Sorry for your troubles that is certainly a bit of bad luck right in the middle of shipping your rig I hope you are able to get it sorted out.
DenisM
4:25 PM
@explorersoverland : There's an Ineos "campaign" to replace the EGR actuators on certain VIN model B57- engined vehicles. Once you get to Perth the Ineos dealer should be able to sort it. There are 2 actuators to be replaced with an "improved design" (according to the Service Manager who processed mine in late July). Hope your transit is smooth and uneventful. Am sure that local Grenadier owner groups across this big wide land will be keen to hear of your adventures :giggle:
Safe travels!
