Quartermaster trailer wiring position?
Mudnut
Quartermaster Owner
7:00 PM
Clifton Beach QLD, Australia
Have just signed the contract for my Quartermaster, and want to install a Redarc TowPro brake controller when it arrives in Q4. The wagons have the brake controller connections under the rear seat. I can't see why theis would be different for the ute. Are there more wiring connections that need to be done at the rear? Is it easy to access the round plug and convert to a seven pin flat plug? Also NATO plug conversion to not turning off when exceed 80 kph? This is to power and charge batteries in Caravan. Most photos on this site show removing rear RHS panel to access some electronics in this area. QM does not have this space.
Base guide is wagon. Hoping not too much different to Quartermaster.
Did you fold the rear seats and see what's behind thr grey panel against the rear wall? May the other electronics are there?
I don't have mine yet, this is why I am trying to get information so I can set it up once it arrives. There are a few around in
Australia now. I just want to get my head around what I need when it arrives. Brake controller a priority. Can run Anderson plug straight to battery to charge caravan.
They are two different approaches to the RedArc installs in Australia, the INEOS method and XHQ approach. I have XHQ and it minimises any changes to the car. The control units can be placed in different positions, user choice.
I had XHQ install the RedArc Tow Pro and Anderson plugs, they have various kits to choose from.
Thanks for the reply. XHQ = Xpedition Head Quartars I am assuming. Located in Brisbane? I live north of Cairns.
Did you get this figured out yet?
Do you have any more information on the differences of install between XHQ and Ineos?
The INEOS approach is in the installation guide posted on the forum. XHQ make up their own loom (AU use a different trailer plug to the US). XHQ's approach did not overwhelm the canbus, like the original INEOS Redarc Tow Pro install did (at least in AU). I went XHQ, I have no issues. I do not know if INEOS have fixed the problems.
This is the XHQ control unit, tow pro box under the dash.
full
Redarc Tow Pro controller next to steering wheel (RHD). I had the REDARC controller installed on a Lightforce Switch Fascia.
full
full
full
Appreciate the insight and the photos!
INEOS installed Redarc Tow Pro issues, only became obvious after towing for hours, but they left the car stranded. Redarc did go and look at the way XHQ did their install (which had no recorded problems, as XHQ did not use the canbus).
Not sure if this impacted INEOS Redarc Tow Pro installs outside Australia.
INEOS did not exactly advertsie the issue (I got some conflicting explanations over time), so I cannot be sure of having the full story, but I do have part of it.
XHQ approach on the Redarc Tow Pro have had no issues, when I last spoke with them several weeks ago (on this topic).
Obviously INEOS is going to fix their issues. They have too.
