Register a free account today to become a member!
Once signed in, you'll be able to contribute to the community by adding your own topics, posts, and connect with other members through your own private inbox!
More akin to sailing when making progress on B roads: View attachment 7799892
Not sure on current gen, but previous versions had ACE (active cornering enhancement) which was a hydraulic anti-roll system. Sort of like the reverse of Jeep sway bar disconnect.
I had a TD5 manual Discovery 2 with ACE for 285,000km, changed the oil in the ACE system every 60,000km very robust system great articulation, rest of the car 2x water pumps, rear wheel bearings, ABS ( 3 amigos ) twice, alternates at 210,000, that was about it.
Good find @Methos - I just found it in the brochure after you mentioned it - so thanks for posting. View attachment 7799882
According to the article below:
The current Wrangler has an RTI score of 532 with the anti-sway bar connected, and 701 with it disconnected.
The current Ford Bronco has an RTI score of 498 with the anti-sway bar connected, and 627 with it disconnected.
Those old Range Rovers were really flexy. I wonder what the current gen is - not very good I fear. Likewise, the new Defender works its way through obstacles using computer-controlled traction - not using good suspension travel - so I doubt the RTI score for the Defender is very good either.
But an RTI score of 585 for the Grenadier is really good - better than I expected. As someone mentioned earlier in the thread, it looks like Ineos improved suspension travel between the first prototypes and the product we have today. Its really good to see signs of continual improvement. That speaks very highly of their commitment to the project.
The Grenadier was tested on a 20-degree ramp, I wonder what the ramp was used in the test below (RTI scores on 30-degree ramps are lower).
The patented AutoLYNX was designed to make disconnecting the sway bar much faster and easier: No need to fight a stuck link. No need to find perfectly flat ground to connect or reconnect. To disconnect the sway bar, just hop out and turn the knob a quarter turn and then do the other side. Takes...
Why?
Me thinks I'll sit back with a bag of popcorn ...
The IG has been designed and developed with a specific purpose in mind... Likewise the Jeep illustrated. Even before the IG has been released faux comparisons are being made trying to equate one with the other. "Different horses different courses"...
More popcorn??? .....anyone?
Why?
See.. my Defender is the same size and 500kg (at least lighter).
The overwhelming impression I get in that car is it's a slapped together hodge podge of absolutely the bare minimum. No kidding when you close the back door the whole body wobbles.
In my old Defender the co drivers door just bounces back if you slam it. I always tell everyone to treat it like a woman. They than slam it with more force and I just look and shake my head . It only works gently but with emphasis.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
