Ahh Sillius, your a friend of Biggus are you not?Might be talking about the Kübelwagen. Those had portal axles if I’m not mistaken.
Ok I didn’t know that the „Thing“ as it is called in the US had portal axles. I should have known better as I tried to buy one from the Bundeswehr 25 years ago. RAL 3000 red from the fire department. 10640 km and like new! It has been sold for 4350 German Mark. I only had 2800…Might be talking about the Kübelwagen. Those had portal axles if I’m not mistaken.
Could you be so nice and search a picture of the VW Kombi wagon? As far as I know in Germany there is no vehicle of VW called „Kombi wagon“ so I guess it is a specific name for some region but probably for a car we know here under a different name.
Ah, the Bulli
I haven’t heard anything like that before neither. Unfortunately it seems to be true anyway. I only started a very short search on google and found immediately some hints regarding the portal axle in the T1These are called "VW-Bus" or "Bulli". The models you show are "T1" versions. I had one from 1979-1981.
The T1 has never had portal axles afaik, I have at least never heard of one. And even the later models T2 .... T6 (todays name) have or had them extremely rarely - if at all. The only model I know is the "Seikel T5", but that was an aftermarket thing, not a Volkswagen solution.
I also only know the Seikel solution for the T5. I had quite a lot of Seikel installed on one of my T5, but the portal axles were then too extreme for the family van (and too expensive and not really practical).These are called "VW-Bus" or "Bulli". The models you show are "T1" versions. I had one from 1979-1981.
That must be something exotic outside of the normal production. But perhaps you have a few links, it sounds interesting.I haven’t heard anything like that before neither. Unfortunately it seems to be true anyway. I only started a very short search on google and found immediately some hints regarding the portal axle in the T1
At your serviceThat must be something exotic outside of the normal production. But perhaps you have a few links, it sounds interesting.
Was mentioned on one of the 12 presentation videos (Probably the suspension one) and stating that cost prevented adding Portal axles.I recall it being mentioned early on that they were looking at portal axles but were focused on getting the base vehicle out first. Sorry I donât have a reference for that.
There is a technical solution for the noise from portal axles: the Bose 12-speaker sound systemThat is one of the reservations I would have with portals. Although I have to admit I've never heard a set in person. But the noise from straight cut gears at speed isn't the most pleasant, you can mitigate it a little with micro finishing etc. I am of course making the huge assumption that modern portals are still straight cut....
Another thing from those 'in the know' is there any issue with overheating? The gear oil will take an absolute beating....
I see there is a Ukrainian company making portals for the new Bronco so its not beyond the realm of possibility for the Grenadier to have some developed by a third party called Werewolf. With a cost ofmy pockets aren't that deep.$16K
Article in motortrend
To avoid the basic conversation my Defender tries to bring up every time I drive faster than 115 km/h I prefer noise cancelling headsets (eg Bose Quiet comfort) I am sure they work well with portal axles!There is a technical solution for the noise from portal axles: the Bose 12-speaker sound system![]()
A recall this week on some of the G Wagens:I think the axles are fairly popular with G wagons, since I think those would look pretty silly with big rubber on them.
I understand that as a rule of thumb portal axles rarely see operating speeds >100kmh due to lubrication issues (at high revolutions) when compared to conventional axles.Anyone know whether the G-Wagon top speed was restricted b/c of portals?
