Owl Outdoor Hidden Light Bar
jwb15
11:03 PM
San Mateo, CA, USA
Good Evening-
Just wanted to share some images of my installed Owl Outdoor Hidden Light Bar
I had my local auto restoration expert install this for me and he said other than some difficutly finding the wiring for the Aux 1 switch the install was simple and straighforward and all of the parts supplied by Owl were perfect.
The light bar is like a work of art and the wiring harness and swithces seemed first rate.
Owl was easy to work with and i received my light bar about 1 week after I placed the order
the install videas definatley helped my installer
sorry the pics aren't a litte better ..i was just too excited to share them
Good Evening-
Love it! Did you do the elite or elite+? Was confused why Owl didn’t have a wiring harness for the Elite+ on the web site
i did the elite plus that has the extra moementary switch for the different intensities and colors
and yes the harness is included in the elite plus pricing/pacakge. Everything needed to complete the installation is included in the elite plus
The Elite does not come with a harness but the Elite Plus does and has more functionality for a net difference of $50 when you take the Elite with harness versus the Elite Plus (comes with harness)
Do you have a wiring digram or pictures on how you wired your elite+?
The harness for the elite+ has a relay included. I wish I'd taken some pictures, but I basically followed the instructions agile has online for their EXT1 wiring harness.
I ran a cable from the power block (passenger side, front) under the top radiator cover, and spliced it into the harness, so all the rest would be on the drivers side. Positive lead from the EXT1 switch to the relay, grounded to the chassis. The factory wiring harness passes through the firewall on the drivers side. I found removing the left front finder well liner made working up there much easier.
For right now, the harness is zip tied to the factory wiring harness under the hood. One of these days I'll go back and cut out the excess length to clean it all up.
The Baja 80's are wired to the EXT 5, using agile's harness. I also ran the extra switch lead for them through the firewall, so I have the 20% dimming feature.
I am wiring the Elite+ right now. Maybe I'm missing it (extremely possible), but the black wire from EXT1/5 is not used in this application...?
Yup. Confirmed. It's been a minute since I have done any upfitter/ aux switch wiring. The added relay box on this light bar threw me off. But it's on, and it's awesome! Huge amount of light coming off this little guy. I won't be bothering with the factory aux light swap, as this thing has me covered for my purposes.
I just installed the elite +, but haven't done the wiring yet. It looks and fits fantastic and was a simple install(Owl's Install videos help a LOT). On the Elite +, with its different light modes, when installing to the Aux switch under the hood, dod you just pick one Light mode you wanted all the time? and use that wire off the harness?
Thanks in advance. Also if anyone has photos of the wiring you did, I would love to see them.
Look at the Triple R lights website for the wiring diagram. I set my customers up with this switch down low so they can rotate through the modes while driving. Its activated on by Ext 1. The momentary ground can be run through the firewall where I take the wheel well out to access. It's actually a longer process but comes out killer.
Slick. Do you have an opinion on which bull bars work best with the hidden light bar?
thanks so much!
