Overhead Console Screw
six1five
GG 319
4:18 PM
Nashville, TN
Hey everyone, what’s the size of the screws that go into the “Grenadier” panel in the overhead console? Picture attached for reference.
six1five
GG 319
4:18 PM
Nashville, TN
Do you have some tools? See what fits.
I should have clarified more, I was able to get one out via 3mm bit, but no hardware store (Home Depot, etc) or Autozone had the right thread pitch. Wanted to get the exact size if possible but longer for a bracket.
Shopkeep
9:18 AM
bigleonski
8:18 AM
Brisbane QLD, Australia
Karoo
11:18 PM
Czech Republic
M4 Socket Caps, I have replaced them on the centre console using these and would assume the overhead console are the same:
https://www.boltandnut.com.au/135-piece-m4-socket-cap-stainless-g304-assortment-kit162
Sorry, but its really not metric screw on overhead console. Yes, it is possible to replace, but with damages, using nails is almost the same stupidity. :)
Be careful with that.
If you know the right screws, let us know. Looks like wood screw, Inox, HEX 3mm (approxim 3,9x13)
Thank you
Shopkeep
9:18 AM
Thank you
Well there you go, see what happens when you make an assumption. In the spirit of being part of the solution and not the problem I took out an overhead console screw and I would suggest they are a metric M4 socket cap self tapping screw (front in picture below, rear two are from centre console). I have the thread length as 12mm but the options I could find online all have points unlike the original so you may be able to use up to 14mm and grind the tip off. There are longer options up to 50mm. There are various sellers on EBay and AliExpress, I have no need to replace these so I will leave up to someone else to buy and try.
parb
2:18 PM
Silicon Valley, CA, USA
You can find them on McMaster Carr. The m4 can be ordered in two different pitches, I forgot which one I ordered. Its easy to figure out when you remove a screen and look at it with the website open.
Quartermaster
Quatermaster Owner
11:18 PM
Yes, but a M4 has a 0,7 mm pitch, because this is the standard. If it has 0,5 it must be named M4x0,5. But i do not want to "split hairs", as we say in german.
But the screw in the front of the picture isn't a M4 and no M4x0,5 in sense of DIN/ ISO.
