- Local time
- 1:03 AM
- Joined
- Jul 27, 2022
- Messages
- 6,005
It was a genuine question not a sarky comment.@DCPU don’t know so perhaps you would like to enlighten me?
...of an oil not available in the UK!
From the Owner's Manual the recommended Engine Oil is Petronas Syntium 0W30 DG.
Haven’t found any references/restrictions the number of turbochargers the oil is suitable forIt was a genuine question not a sarky comment.![]()
One could interpret the photo as a massive overfill.I tried to take a reading but it's not that clear to read, other than yes, there's oil in there.
Was the motor cold, did you clean off and dip again? Sunlight on the gauge helps see the level.View attachment 7813287
And yes, I tried to take a reading but it's not that clear to read, other than yes, there's oil in there.
Is was difficult to read the dipstick after a couple of dips.What was the oil-level when you inspected the dipstick? Was it between Min/Max and did you have the same readout at the display?
So is it only intended for a quick oil change? And if there are marks on the stick, what are they for?"WARNING: The Diesel B57 engine does have a dipstick in the engine bay, however this must NOT be used to check engine oil level."
I pretty much ignored it.
Well it's definitely there, so those that like the vacuum method of removing oil at least have a way in.So is it only intended for a quick oil change? And if there are marks on the stick, what are they for?
Any BMW specialists here?
if the oil meets the specification set out by ineos, which many people have posted again and again and again and even a picture a few posts above then it can be used in the car. Marketing material does not overide the laboratory tested specification of the oil. If Ineos are saying the diesel spec oil is LL-12FE then you can use LL-12FE spec oil no matter the colour, brand, marketing, shape of bottle, etc.We are in danger of replicating the other oil thread:
But in summary many of the spec sheets for the BMW spec oil state they are NOT suitable for multi turbo engines. We have a multi turbo engine...
Ineos have said many things that have turned out later to be incorrect, what's hard to understand about asking them for clarification/confirmation on an issue as important as this?
I look forward to you trying to jack the rear of the vehicle off the place Ineos say you should without applying even a modicum of common sense, just because they say you can.
My earlier posting is wholly incorrect - my apologies. Oils are not available for order or supply through the INEOS Parts system.The Petronas Syntium 0W30 DG engine oil apparently is available to order as a specific INEOS part through any INEOS Sales or Service Agent and supplied from the Belgium Parts Centre - sorry I don't have the specific part number. Sounds expensive to me buying oil in this manner, I supect buying oil meeting SAE 0/5W-30 BMW LL-12FE for diesel, SAE 0/5W-20 BMW LL-17FE for petrol will be cheaper.
That is the purpose of specifications. For a standard engine.if the oil meets the specification set out by ineos, which many people have posted again and again and again and even a picture a few posts above then it can be used in the car. Marketing material does not overide the laboratory tested specification of the oil. If Ineos are saying the diesel spec oil is LL-12FE then you can use LL-12FE spec oil no matter the colour, brand, marketing, shape of bottle, etc.
That's never been the issue ~ why pretend it is?It’s confirmed, stamped there on the car, the words convey the information you are seeking.
Compromise and put 250ml and then re-measure??For info I just carried out an oil check in a diesel N1 5 seater post c830miles, all looks ok albeit my instinct would be to put in another 500ml to be on safe side on and off road (can this be done or is the vehicle then over filled for road use?)
Yes perhaps that’s the right compromise and least “bad” option (ie slightly too much oil for road use and slightly too little for off-road)Compromise and put 250ml and then re-measure??
