Thank you!Here are both the 25A and the 10A pairs. The rearmost one is the 10A. Look for the shiny PVC tape on the wiring harness behind the airbox
Hey Hans,
Thanks mate.
1. The sliders are just far enough out to get a boot on. Ergonomically they are a bit too high to enter and exit comfortably. The trade off to maintaining good ground clearance.
2. I find the 2.5m long roof rack adequate. Enough room for a 2.1m roof tent plus jerrycans etc.
3. The muffler makes no difference at all. Even under load at high revs. I have seen it removed from a petrol and it made a big difference. I believe it’s mainly for the petrol and has just been left in the diesel which doesn’t really need it due to having 2 turbos a cat and a dpf to attenuate the exhaust noise.
All the best, Dan
Any idea of the weight of your drawers, refrigerator and other items in the back?Rear Storage / Drawers:
Off Road Systems were one of the first people that i heard had access to a Grenadier and would sell drawers, so being the impatient man i am, i bought them. They shipped them to me and i assembled and fitted them myself.
I went for a drawer fridge as i still wanted space on top of the drawers, plus it's easier for my lady to see into.
In the side/wing pockets of the drawers i was able to fit:
ARB twin compressor on the jack side, with room to get the jack past the compressor, just. plus switch and hose connection on the face just inside the small door. there is still room in that wing space for a little bag that's home to my hoses and inflators etc.
2000W invertor (240V) for coffee machine and an induction cooktop - this means no gas, so basically unlimited cooking power for longer trips
50A anderson accessory point. this is basically spare so i can run 12V to whatever i want. Eg a second fridge etc
Battery monitor for the Aux lithium, along with a solar input and a couple of USBs for phones etc.
Lastly i made a shelf for up the top of the cargo space, which you can read about in this post here: https://www.theineosforum.com/threads/diy-rear-cargo-shelf.12414074/
fridge ~28kg, drawers about the same, compressor 8kg, shelf 2kg, inverter 2kg,Any idea of the weight of your drawers, refrigerator and other items in the back?
Were they a member when you met? Certainly I hope they are here now!Met another owner and helped him with a few mods on his car. Met up again on the weekend to take them both for a run along the beach
I think he was, we have both certainly spoken of this forum.Were they a member when you met? Certainly I hope they are here now!
And the more the merrier. What I love about our members is the pure diversity - we're a very eclectic group and range greatly in age, nationality, career choice (and retired), etc. Makes for a great place to hang out.I think he was, we have both certainly spoken of this forum.
We have about one grenadier per 12000 people in my area, close to 200 vehicles now.
I’ve met a few owners via mutual connections that have put us in touch. Becoming a neat little community supporting one another
That's a fine looking MM FM behind you!Met another owner and helped him with a few mods on his car. Met up again on the weekend to take them both for a run along the beach
Better watch what I say from here…..That's a fine looking MM FM behind you!
Looks sick! Does the light bar help with the wind noise of the rack at all?Adjusted in some more caster last week. Approx 5mm. I marked the bushes to I can go back to where it was. Haven’t taken the time to put it on the turn plates yet to check degrees.
Done about 1000km since, incl highway towing.
The steering is a little heavier, return to centre is slightly better. There is also more feel from the steering wheel. Not a polar shift, but noticeable.
Previously I’d removed the dampener to get a feel for using a lower dampening rate unit.
After some rough road testing, I decided I would prefer to stick with the factory dampener, so went the route of playing with caster.
Photo from the test trip
Depending where you place it. This one works as shown and makes very little noise.Looks sick! Does the light bar help with the wind noise of the rack at all?
What is the brand of the light bar? Ineos offering?Depending where you place it. This one works as shown and makes very little noise.
I’ve added rubber strip into the fins on the back of the light bar previously to help too.
Stedi. Check out post #24 on page 2What is the brand of the light bar? Ineos offering?
Lightbar:
Full length roof racks have light bars on the front, big ones. Thats just how the world works.
I went with 50" ST-X bar from stedi, attached to the rack with their LED mounts
i wired it to the RHS front roof outlet, but wasn't happy having it on the overhead switch. So i found the relay that runs the ext2 circuit (pictured) then cut the trigger wire to it so i could attach a new one (so the overhead switch no longer works). I took a power feed off the front spotlights on the grille and ran the wire through the firewall and along the sill to get it under the back seat. Then I joined it to the relay where I had cut the old trigger wire off.
Now the overhead light switches on and off at the same time the front ones do.
Lightbar:
Now the overhead light switches on and off at the same time the front ones do. win!
Hi Mate,Lightbar:
By trigger wire, I mean the wire that triggers, switches, or actuates the relay. Not its power feed, just the switch wire.Hi Mate,
What do you mean by trigger wire?. Is it overhead on/off switch for front driving lights.(OEM)?. I bought 4" Narva driving lights with builtin relays. Harnes has only power and hibeam trigger. Did you use overhead switch wire as a hibeam trigger?
Thanks
