NEW GP Factor Hidden 12.5K Winch Kit - Synthetic Line
GPFACTOR
Supporting Vendor
12:17 AM
United States
Good Morning,
IN case you dont see our vendor thread, We are proud to finally announce and release for preorder our 12.5 Hidden Winch Mount. Here's the info and dont hesistate to ask questions. ill be on here most of the day to answer. ALL ORDERS PLACED ARE PREORDERS IN THE FIRST BATCH. WE ANTICIPATE TO SHIP THE FIRST BATCH END OF SEPTEMBER - FIRST WEEK OF OCTOBER 2024. ALSO, The FORUM DISCOUNT WILL BE AVAILABLE TO USE FOR THIS DURING THE PREORDER PERIOD. WE WILL ALSO BE INCLUDING A SPECIAL GIFT INCLUDED WITH ALL PREORDERS PLACED WE WILL SHARE NEXT WEEK! IG-0200-11-WEB.jpg
Cheers!
This kit seamlessly integrates into the original bumper shell, preserving the vehicle's stock appearance without requiring any alterations. Featuring the robust Come Up 12.5k SealSlim winch, equipped with 65ft of synthetic line (55ft usable), Increasing the length of the usable line over the factory winch by 83%, ensures you're prepared for any off-road challenge.
Included in the Kit:
GP Factor Winch Mount, Fairlead, Hardware for Installation, Come up Seal Slim 12.5 RS Winch.
Specifications for Winch Mount:
Material: Constructed from full 1/4" steel, ensuring durability and strength.
Finish: Coated with Zinc Primer and finished in textured black, providing both corrosion resistance and a sleek factory appearance.
Fairlead: Proprietary 6061-T6 2.25" thick Billet Aluminum fairlead with Type 3 Hardcoat Grey Anodized Finish
Fitment: Compatible with all Ineos Grenadier Models featuring the factory metal bumper. Maintain its original aesthetics
Winch Mounting Configuration: Foot Foward
Weight: Approx 100 lbs for winch mount and winch - (Removal of the factory internal bumper will make your net weight approx 70lbs added)
Specifications for Come Up Seal Slim 12.5 RS Winch:
*THIS WINCH IS ONLY AVAILABLE IN THIS KIT AS IT WAS SPECIFICALLY MADE TO FIT THIS KIT, VEHICLE AND PER THE SPECIFICATIONS NEEDED.
  • Rated line pull: 5,670 kg / 12,500 lb single line
  • Line speed ( 1st layer): 7.7 mpm / 25.3 fpm 45 A at 12V no load
    0.9 mpm / 3.0 fpm 470 A at 12V full load
  • Motor: 3,730 w / 5.0 hp 12V series wound
  • Gear ratio: 3-stage planetary 225:1
  • Clutch (freespooling): Rotating ring gear
  • Brake (outside the drum): Automatic, full load CBS (Cone Brake Structure)
  • Winch construction: Aluminum die cast housings with steel drum
  • Drum size: 63.5 mm x 227L mm (2.5” x 8.9”L)
  • Control: Both built-in digital two way signal wireless remote control and waterproof remote with thermometric indicator LED w/ 5 m (17') cord
  • Rope type: Synthetic rope
  • Rope size: 65' - (55' Approx Usable)
  • Mounting bolt pattern: 254 mm x 114 mm (10” x 4.5”)
  • Mounting : Foot forward mounting workable
  • Finish : Matte black powder-coated
    * Remark: Only foot forward mounting can meet SAE J706
Here's the direct link to GP-Factor's pre-order page on the website: GP-Factor Hidden Winch Kit. The cost is $3,499, or, the way I like to think about it, $586 cheaper than the OEM winch option (before applying the forum discount code savings).
Questions for GP-Factor:
I believe this is the case, but please confirm the OEM Bull Bar can be installed to the front bumper with no issues after the GP-Factor hidden winch kit is installed.
What is the warranty on the kit, including the Come Up winch?
Does GP-Factor only cover the warranty on everything except the winch itself? That is, do warranty claims regarding the winch itself have to go through Come Up?
Since it is specially designed for this kit, and, thus, not available off the shelf, is there an option to buy a replacement winch if the original fails outside the warranty period and needs to be replaced and, if so, could that be purchased through GP-Factor or would we have to go through Come Up? And what would the price of that replacement winch be?
These questions are pertinent, because there are other winch options coming along for the Grenadier that appear to allow the purchase and drop in of after-market winches, though they are not hidden winches like GP-Factor's offering.
Thanks for putting together such a great offering and I look forward to learning more about it!
It does wire up to the factory 500amp hookup behind the
ill Try to make sure to answer all your good questions:
I believe this is the case, but please confirm the OEM Bull Bar can be installed to the front bumper with no issues after the GP-Factor hidden winch kit is installed. - Should work no issue as our bull bar that is coming soon here attaches the same was a the factory one and all the mounting points are the same. Its really a direct factory replacement.
What is the warranty on the kit, including the Come Up winch? - from our site - "GP Factor warranty it’s products for lifetime from manufacturing defects. Although most defects are found immediately upon inspection or first use by customers, as a result, We therefore hold a 1 year warranty to return items to us for full replacement or repair if needed due to manufacture defects. If you have a unique circumstance, please contact us. GP does not warranty normal wear and tear, end user use, or end user abuse. Please contact us if you have any questions in regards to our warranty. Thank you!" -So what this means is, if there is a defect, it should be found pretty early on so we can fix and replace. But we work with all of our good customers to make sure everyone is taken care of. We are just not Costco where a customer could use a product for 6 months and return it no questions asked. lol The Come up Winch I believe is a 3 year limited warranty and lifetime limited warranty on defects.
Does GP-Factor only cover the warranty on everything except the winch itself? That is, do warranty claims regarding the winch itself have to go through Come Up? - The winch warranty would work through Come up USA. That is why we chose this winch because their support is amazing and we plan to aid customers in that and make sure they are taken care of. Nothing is worse for us than warranty work for us or our end users with another manufacturer. They are awesome with this.
Since it is specially designed for this kit, and, thus, not available off the shelf, is there an option to buy a replacement winch if the original fails outside the warranty period and needs to be replaced and, if so, could that be purchased through GP-Factor or would we have to go through Come Up? And what would the price of that replacement winch be? Would have to be purchased through us or one of our authorized dealers if just purchasing the winch as a replacement.
Outstanding! I caught a glimpse on youtube a while back and have been waiting...
How does this fit with a right hand drive vehicle, and does it wire up to the factory winch circuit?
One more thing, any ballpark figure for shipping to Australia?
not sure on right hand drive but I know our UK distributor has ordered them so they plan to install based on their experience. The website will quote shipping but you can email us so we can give a quote. Will need full address.
Will the OEM flip-up license plate holder mount with your setup or will you have a new holder design?
Hi AJ,
I just ordered the winch. What do I need to do to get the front license plate holder? Or do I move over the stock one?
EDIT: just talked to AJ. A bracket will be available in time for the pre order shipping. They are working on making sure it's easy to use and robust for real world use. Super nice guy, I feel really confident about the order.
He also shared that the winch manufacturer will directly warranty the winch and handle spare parts. I quite like that too.
Does the winch work if engine is NOT running. Winch might be the only hope to get out from the mudpot when engine is not running. Battery has usually enough power to get the car to dry land...2-3 metres what it needs..
only if you dont wire it to the 500a hookup. If you wire directly to the battery it would.
Some more Pics of the kit and a little update for everyone that ordered a winch kit and is thinking about ordering one. Cheers!
Do you have an estimated weight difference between the stock bumper and the installed GP winch?
In not sure of the exact weight of the factory internal
Bumper but my guess would be around 30lbs. Our internal mount with fairlead weighs approx 50lbs. The winch according to Comeup weighs 65lbs. So net added weight is probably right around 80-85 lbs. I’ll try and get some more exacts soon here on the factory internal mount.
Update with official weights - the factory internal mount (non winch) weighs 22lbs. Our mount with winch, fairlead, line (fully assembled) weighs 111lbs. Net weight added of 89lbs.
Good Morning,
Cheers!
Are the holes on top for adding lights or light bar?
