New GP Factor Grenadier Bull Bar
GPFACTOR
Supporting Vendor
12:15 AM
United States
Good Afternoon Grenadier Fam!
If you dont see the other thread in our vendor section:
Introducing the GP Factor Ineos Grenadier Bull Bar Grill Guard. Our mission in designing this bull bar was to create a strikingly aesthetic yet robust and functional product for the Grenadier, and also fully made right here in the USA. The result is a uniquely crafted bull bar made from five separate pieces, rather than a single solid unit, allowing for enhanced versatility and ease of use. Here are some key benefits of our innovative design:
  1. Easy Replacement: Damage to the outer sections can be easily fixed by replacing only those parts.
  2. Versatile Options: Middle tube sections can be swapped out to accommodate various light mounting choices in the future.
  3. Effortless Shipping: Individual pieces make shipping simpler and safer, reducing freight costs and eliminating complications at the time of delivery.
  4. Enhanced Durability: Our multi-piece design is engineered for superior strength and longevity. Constructed from 3/16” (0.187) HRPO A36 Carbon Steel with 1.9” diameter tubing featuring 0.125” (1/8”) thick walls, this bull bar is built to withstand the demands of rugged use. The main pillars boast an I-Beam construction for added strength and an impressive look. With pillars and bar mounts all measuring 3/16” thick, when assembled, the combined thickness reaches 9/16”.
The bull bar mounts securely to the bumper using eight factory mounting holes on each side—four M10 in the front, two M6 at the top rear, and two M6 on the bottom—to ensure stability and support without any modifications required. All included hardware is crafted from A4 Marine Grade Stainless Steel with a Black Oxide Finish for superior resistance to corrosion.
Specifications:
  • Material: A36 Carbon Steel HRPO
  • Finish: Sandblasted, Zinc Primer, and Textured Black Powder Coating
  • Weight: Approximately 64 lbs
  • Origin: Full Made in the USA
  • Compatibility: Factory Bumpers with or without factory winches, and factory bumpers with GP Factor winch kits.
Available for Preorder - First batch shipping in November: https://gp-factor.com/products/ineos-grenadier-bull-bar-kit
Couple pics from some trail time last weekend in NC with Ineos North America, Triad Ineos, Design Build Go, MSO, and OEX! This truck loves the trails. 🥳⛰️ The Bull Bars are currently available for preorder. Don’t forget you can use the Forum Discount Code for preorders. “IGFORUMFAM10” Cheers Fam!🍻
Nice post and awesome looking bar y’all got there!! When you said “This truck loves the trails” it made me smile as mine haven’t hit the trails yet, but we have a trip planned at the end of the year when one will be Baptist in off roadness (yea made it up). Thanks……👍🤘
Darn in. I forgot about the coupon code. :(
What is the possibility of having only one coupon code for all products?
That code should work for anything on the website. I just double checked and made sure it does. If it didnt before, it was a specific collection wasnt under it. Now they all are (y)
