Americas Making a spare key?
Jeffrey
Forum Donor
8:33 AM
Santa Barbara, California, USA
Anyone in the USA have a spare key made? Do you have to go thru the dealer and give them half your life savings? Or can we make a mechanical one at a lockshop to use in an emergency?
Making a mechanical one won't be the issue but I'm not clear how to overcome the immobiliser with a " mechanical " key.
So if you remove the battery the car won't start?
Must try it.
Must try it.
Hum...I'm sure I'd seen some where you can start the car with a dead battery??. But how is the immobiliser controlled?? I'm being to think there are lots of issues/reasons why the alarm and immobiliser aren't Thatcham approved.
I just took the battery out. Car started normally.
I mean , it's designed to deal with harsh conditions, such as dropping the key into the sea...
That's good to know. So must be some sort of RFID, which surety means you can't start it with a spare cut " mechanically " cut key
So if I drop the key into the sea I'm stuffed?
If the coil corrodes, yeah. Whenever I'm on vacation somewhere at the beach our rental car tags always warn about how expensive the fines will be if the key gets wet.
Doesn't sound like a key for remote adventurers then.
I'll have to take extra precautions.
Maybe we need @OverlandGearGuy to whip up some nice waterproof bum bags. The 4Runner I had came with a nice sealed "dumb key" with a transponder but no buttons. Ineos missed a big opportunity.
Years ago I had a VW Touareg that came with a 'sand key' - a plastic version of (only) the metal part of the key.
Woulda been handy, Ineos.
(Presume you could then lock your actual key in the car, but not sure what the car would make of this regards the alarm/ immobiliser etc)
Guy on FB had one cut by hand from a Renault blank.
All you then have to do is hide the main one under the car or in the bushes.
I've been meaning to visit my locksmith.
