Leitner 3/4 Lighting options-- Would like to see what light bars you are running
5:11 PM
Florida, USA
Tried searching but havent found anything related specifically to the leitner 3/4 rack (with safari windows). Has anyone run the onyx lightbar from baja? If not what light bar have you mounted?
-Any glare thru the safari windows?
-If the amperage is above 25 amps what have you used to deal with this?
-Crazy wind noise? Hopefully in can be mounted flush to the front of the roof rack so that it blends and should change noise or wind resistance
Thanks again for any help and if any one has some pics that would be helpful as well.
I did the factory offered rhino cross bar and mounted the LED bar below it. It’s forward of the majority of the safari windows so there isn’t any glare.
Do you have safari windows? If so, how much does this light bar cover them?
Yes, I have Safari windows, but I haven’t ordered this light bar yet. According to the description from Blacksheep, 'The functionality of the Safari windows is not affected; they can still be opened and removed.'
