Left Rear Barn Door Not Closing
VictorM
4:42 AM
USA
When I was on a trip this weekend , an issues with the left (small barn door) doesn’t shut because the button you push to open the door satays suppresses and does not release.
basically you can’t fully close the door. Or can you lock the Grenadier.
Has anyone heard of this and any fixes? Still on the road hundreds of miles from my dealer
Probably the same door button issue that some have had with their side doors. I think the dealer replaces something to fix it but for the short term I've seen people recommend slapping the door under the handle or spraying lube around the button. Good luck!
Yep, Does it most times. I have got into the habit of easing out with my thumb. Spraying with graphite on ptfe spray works for a while. They tried fixing with a rubber ring on the inside to no avail. Replacement handles would appear to be the logical step. I'm surprised though you haven't had the same problem on the other 4 doors
Thanks. Concerned they don’t have a real fix yet
Many thanks. I tried slapping under the handle. To no avail. More difficult with the ladder in the way. I’ll have to carry some lube going forward and a lighter pressure when depressing the button until such time I can get the dealer to fix
Try pressing the button in the 9 o'clock position, towards the three.
Thats all I do and no issues it always pops out
