Lazer Linear light onto Rhino Cross bar?
Trialmaster
4:42 PM
North of Watford!
Has anyone fitted a Lazer light onto a Rhino-Rack Cross Bar.
Was thinking of Linear-42 or similar. Link: https://www.lazerlamps.com/linear-42.html
Power Consumption147 Watts
Current Draw (at 14.4V)10.2 Amps
It shouldn't overload the pre-wired system, thoughts?
The Deutsch DTP rooftop circuit normally used for the OEM lightbar is rated at 25 amps, well above the 10.2 amps of the Lazer.
Lightbars can normally be fitted to Rhino Roof bars. Speak to the UK Agent for Rhino Rack to find which bracket you need.
United Kingdom
TBR Accessories
01832 275396
0800 16 999 47
sales.team@tbruk.com
Unit 3 Axis Park, Manasty Road, Orton Southgate, Peterborough PE2 6UP
One rooftop circuit is rated at 25 amps, the other 3 rooftop circuits share a 25 amp circuit.
Usual rooftop circuit for LED lightbar in RHD car is driver's front side rooftop outlet, but double check with your dealer. It is on AU spec cars.
Lots of this information is in the Rok Dr Guide.
I have the linear 42 elite. It's mounted on a bison rack crossbar but that should be the same for your application. Make sure you buy the optional mount, the one that comes with the light isn't working well for a cross bar mount. It's on their website as optional accessory.
Really nice, almost a bit too powerful. Reflectors like in traffic signs reflect a lot of light back. No diffraction into my safari roofs or into my hood.
I also have the agile off-road Baja 80 lights in the grille, I find that this by itself is really great combo. In hindsight for the majority of driving I think that is enough of lights and that the lightbar isn't adding enough to make a difference.
My few cents
