Interior Panel Clips - Part number or Cross Reference
LWA55DAL
6:39 AM
San Antonio, TX, USA
Curious if anyone has found a part number or comparable replacement to the trim panel clips for the IG? I had to pull the B-pillar panel and despite being VER careful and using a trim panel tool, I broke 2 of them. Here are a couple pictures of the clips. Any help would be appreciated as the dealers don’t show a part number.
Worst case - I have a pretty good inventory of Toyota clips, but while they have the rubber isolator, they don’t have the full seal like the factory IG clips. I have to assume someone else uses the same clips, but have tried, BMW, Mercedes, etc and none of them are this design.
Thanks
Afraid nothing I know of - but very interested to hear as a couple of these fell out the bottom of my drivers door when I was rattle hunting. So broken from factory :(
Those look similar to trim clips on Jaguars. I don’t know if they’re the same size though. Search for Jaguar part number C2D3422.
Thank you! That is exactly what the clip looks like and makes sense that it would be a Jaguar clip.
Here’s another link with size info:
Thanks! Those have to be the correct ones. There is a smaller version that is a little stubbier, link below, but the ones you sent look identical. I called the local Jaguar dealer and they were only $2.50 each so I just ordered them through Jaguar. Link below to the other clip, but I think C2D3422 is the right one. As soon as I have them in hand I will report back, but thanks for the help! I never thought to try JLR.
CORRECTION - just measured the old clip with calipers and the stubbier one is the correct one based on the dimensions.
So the below is the correct version.
Ok - so it appears that this clip is used by a number of OEM’s and below are the cross referenced part numbers.
Update - I found the Ford # on Amazon and ordered them. They are identical to the factory clips and a FRACTION of the cost. I got 20 of them for $6 on Amazon. Land Rover wanted $9 each!
Hi @LWA55DAL. Do you happen to have the link to the items on Amazon? The ones I found don't quite match the factory clips. Thanks.
I had the same issue. The amazon ones are smaller head but seem to work as the tips seem the same.
I search for the ones you’ve shown and could not find anything with a head similar.
I ordered these from Amazon (U.S.) and they seem to be a pretty darn good match based upon my measurements:
At about $6.50 for 50 of them, they're reasonably priced.
Here's a clue - for what it's worth, the round top part of the OEM clip is stamped with what appears to be "Fx" and then on the opposite side there is the number 6 (or 9 depending on how you look at it):
I broke a few clips removing the door cards - they're different from those pictured and linked above:
View attachment 7881639 View attachment 7881640
I bought the amazon clips linked above (https://www.amazon.com/dp/B0CRRVFCCC?tag=globalgrena0b-20) and they mostly seem to work - I mean they're holding the door card in, what more can I ask for?
I think there are a couple different clips in the vehicle. I haven’t pulled the door card, but the trim clips in the B Pillar and cargo area were exactly like the ones I ordered.
