Inner Door handle - small rear door
MunichMax
5:50 AM
Just wanted to show you this little upgrade i just installed. Makes closing the door from the inside way easier…
Alu handle for 4€… some bolt in nuts and srews. Strong enough even the bolts just sit in the plastic cover.
What do you think?
What are your solutions to this?
Hi, I have fitted these to mine. Bought off ebay for £16, they come as a pair so that you can fit one to each door. Easy to fit using the existing rear panel fixings.
Pictures below taken from the ebay listing "Rear Door Roll Bar Grab Handle Rope Tactical Hanging Board For Ineos Grenadier". You can get them in red, yellow or blue.
I've been very pleased with them. You don't need to pull hard on them - they help to get the door from fully open to 45-degree closed, at which point I then push the door closed from the ladder or spare wheel. However, the main reason I bought them is to make it easier to close the doors from the inside, which I periodically need to do when travelling.
