- Local time
- 7:22 PM
- Joined
- Jul 26, 2022
- Messages
- 693
- Reaction score
- 1,735
- Location
- Toowoomba QLD, Australia
Thanks for the reminder @bakepl.this VW part also works... diesel at least not sure about petrol.
Volkswagen Genuine VW TDI Diesel Fuel Nozzle 000072709
I had tried to obtain this genuine VDub adaptor a couple of times but it was always out of stock. Currently available from Amazon. Cost me A$36.69. Delivered in 12 days ex-USA.
Length 135mm
Filler end OD 25mm (bottom)
Nozzle end ID 42mm (top)
Nozzle recess depth 25mm
Haven't used it yet. I expect it will take some trigger whispering to refuel without blow back or nozzle cut-off.
Reminder: You only need a solution like this if you're refuelling a diesel Grenadier from a hi-flow pump that is fitted with a large diameter nozzle, as is often found at truck fuel stops in Australia.
