Help me identify this part I found in my driveway
Pessimal
11:34 AM
Hi Guys, found this part with an Ineos logo in my driveway. No Idea where it fits to my car though :(. It looks like a small rubber damper of a door or similar. Bit bigger than my thumb. Does it look familiar to any of you? Would be very grateful for any hints
Lag bei mir auch lose im Kofferraum mit der Schraube als ich mein Fahrzeug abgeholt habe. Hatte wohl jemand bei der Endkontrolle vergessen anzuschrauben.
Mine also fell off - no real thought in the design as the screw buts straight onto the rubber - inevitable they will all fall off unless you fix it with a serrated washer or similar
Also someone unfamiliar with the door opening mechanism could pull it over the head of the screw if the were trying to find the large door lever.
Thanks everyone, back where it belongs for now must remember to add a washer or something no Idea if the screw was loose or it just slipped off.
The issue of this falling off has been shown a few times before in the forum. It appears that it needs a large washer to keep it from being pulled off the bolt when you close the wrong door first. DaBull
I searched it yesterday as well. Happily a friend dropped in with his two days old Grenadier. Do I could check.
The screw has been loose…
Hi ,
I have joined the club, found this rubber stop on the floor, but couldn't find the screw,...... anybody knows the size?
Thanks.
Seems to happen to most of them. Dealer re fixed it but I suspect it needs a bigger washer.
WOW. I found the same piece. It is like Cinderella's Shoe 😁.
Make up some washers as I did. There are two that fall off and need washers .
I nice little job to do over Christmas
Ive put some pictures on Logsplitters travels thread somewhere
There is an inside part to the female bigger rear door receiver. Its located at the bottom of the boot where the door male point closes in.
I found the inner part lying on top of the rear bumper and took a little working out what it was. A little super glue may help in future.
