S.O.S. Heater core/lines
IslandFalconer
10:31 AM
Prince Edward Island, Canada
Ok gang, has anyone torn one of these down to the heater core area? Or have an idea of the line work to the heater core. After 3 months at the dealership I get my truck back only to have coolant smell and mist/liquid coming out of lower vents. I need to figure out a way to cut off coolant to the air box or I’m going to poison myself, and since it’s my only winter vehicle I’m in need of wheels until the dealership figures out how to resolve this yet again.
Tinerfeño
2:31 PM
San Juan de la Rambla, España
Sorry, I don't know the answer to your question.
Do you know what has been done by the dealer? Is it possible that the smell isn't just residues of the work done? Have you tasted the liquid you see?
By-passing the heater core circulation will make the winter use very difficult as cabin will be very cold and windows will be internally covered with condensation.
Vote:
IslandFalconer
10:31 AM
Well what they did was remove the entire dashboard, heater box and associated parts and re sealed the A/C condensation drain. In so doing I guess they did something. I know it’s not residue because there is cool and coming out of the lower vents consistently when running the heater. And yes I know it won’t be pleasant in the cold, but right now until they figure out when they are picking this up and such I need to be able to get around.
Vote:
Clark Kent
12:31 AM
Toowoomba QLD, Australia
The gift that keeps on giving for you 😞
I know you're in the automotive trade so you'll know the 14-16mm hoses to look for at the firewall. Physically getting access to those fittings to run a bypass could be a problem so you might need to locate the hoses at the engine end. I just had a quick look at mine (diesel) and I can't see them at all.
According to these schematics the heater inlet hose might be in a T fitting in a crankcase return line, and the heater return hose goes to the heat management module (HMM) on the LHS of the engine. The heater return hose might be visible from below to trace it backwards from the HMM to the firewall. But these are just schematics so may be useless here.
Are you also losing coolant from either reservoir? I suspect the heater circuit is supplied from the high temp/pressure circuit. If you're not losing coolant it's still possible that you're seeing residual coolant dripping out of the vents because a careless mechanic slopped coolant into the HVAC unit when he/she popped the heater hoses off the HVAC housing. Wishful thinking probably.
Vote:
IslandFalconer
10:31 AM
Yeah it’s freaking tight in around the engine.
Vote:
IslandFalconer
10:31 AM
@IslandFalconer you have the worst luck of anyone i've ever talked to my friend. My gosh have you not been through a lot.
If possible, and at the expense of going on a longer drive, maybe take it to another dealer?
The only other dealer in Canada is on the other end of the continent.
Vote:
