Heater core/lines
IslandFalconer
8:58 PM
Prince Edward Island, Canada
Ok gang, has anyone torn one of these down to the heater core area? Or have an idea of the line work to the heater core. After 3 months at the dealership I get my truck back only to have coolant smell and mist/liquid coming out of lower vents. I need to figure out a way to cut off coolant to the air box or I’m going to poison myself, and since it’s my only winter vehicle I’m in need of wheels until the dealership figures out how to resolve this yet again.
Sorry, I don't know the answer to your question.
Do you know what has been done by the dealer? Is it possible that the smell isn't just residues of the work done? Have you tasted the liquid you see?
By-passing the heater core circulation will make the winter use very difficult as cabin will be very cold and windows will be internally covered with condensation.
Upvote 0
Well what they did was remove the entire dashboard, heater box and associated parts and re sealed the A/C condensation drain. In so doing I guess they did something. I know it’s not residue because there is cool and coming out of the lower vents consistently when running the heater. And yes I know it won’t be pleasant in the cold, but right now until they figure out when they are picking this up and such I need to be able to get around.
Upvote 0
The gift that keeps on giving for you 😞
I know you're in the automotive trade so you'll know the 14-16mm hoses to look for at the firewall. Physically getting access to those fittings to run a bypass could be a problem so you might need to locate the hoses at the engine end. I just had a quick look at mine (diesel) and I can't see them at all.
According to these schematics the heater inlet hose might be in a T fitting in a crankcase return line, and the heater return hose goes to the heat management module (HMM) on the LHS of the engine. The heater return hose might be visible from below to trace it backwards from the HMM to the firewall. But these are just schematics so may be useless here.
Are you also losing coolant from either reservoir? I suspect the heater circuit is supplied from the high temp/pressure circuit. If you're not losing coolant it's still possible that you're seeing residual coolant dripping out of the vents because a careless mechanic slopped coolant into the HVAC unit when he/she popped the heater hoses off the HVAC housing. Wishful thinking probably.
Upvote 0
Yeah it’s freaking tight in around the engine.
Upvote 0
@IslandFalconer you have the worst luck of anyone i've ever talked to my friend. My gosh have you not been through a lot.
If possible, and at the expense of going on a longer drive, maybe take it to another dealer?
Upvote 0
There are only 2 dealers in Canada currently... However, a drive to a US dealer is actually closer for him
Upvote 0
I'm pretty sure the heater lines on the petrol models pass through the firewall/bulkhead just aft of the left (DS) rear corner of the engine. Pop the engine cover off and look about a foot behind the oil filter housing and slightly lower and you should see where they enter and exit. The lines run forward and I think one connects into the main large radiator hoses close to the front radiator fan on the front left. IIRC the other is more easily traced from underneath but it's been a few months since I had a serious look.
If you've got a leak in the heater core then the cabin should be steaming up even with the engine fully warmed up and the heat on. The windows will feel sticky on the inside.
Upvote 0
Oh it’s nice and moist inside, and the smell and taste are even better! The coolant coming from the vents is an extra nice touch. It’s definitely either the core itself leaking or a loose connection where the lines connect to the core and it’s leaking in to the air box. Either way something is not right. But as I started to pull panels it only got worse. The tech omitted plastic cover clips, broke the locating dowels off the two lower center dash covers, omitted bolts and screws. And the dealer thinks it’s all good. And questioning me on how it could be coolant. Just a circus
Upvote 0
Update!! They are sending a loaner and taking this one back to the dealership.
Maybe they will get it fixed this time.
Hopefully they can fix all the stuff they didn’t manage to fix after 3 months of having it.
They should make the guy from the dealer that said everything is hunky dory drive it all the way back to the dealership and see if his "assessment" changes.
Upvote 0
I’ve lost all faith in the dealership. Anyone whose work is this bad has zero pride in what they do. They broke so many parts and forgot a bunch it’s a wonder the thing actually started. If there was another dealer I’d be going elsewhere
Upvote 0
You seem to have some US grenadier employee contacts and know more than you let on, so, is there not a god damn factory rep that can intercede with this friggin dealer for a customer? Other car companies have them. Is there no one working for Ineos in the NA market that can deal with this? This is amazing.
Upvote 0
I think it is fair to say that there are three sides to every story... His side, her side, and the truth.
Upvote 0
Well there seems to be no Company or factory rep that speaks to Canadian customers. And so I’m stuck dealing with the dealership. And if you think I’m lying well that’s a very interesting proposition. Because I so enjoy spending 100k for a truck that has spent more time with the dealership than with myself since I purchased it.
Upvote 0
I didn't read that lying was implied. There is a point of view that varies depending on where you happen to sit or stand, all of which likely make sense from that perspective.
By virtue of how I was taught to work on vehicles, I too pick up on details that most won't, and sloppy work with missing fasteners (only stripped fasteners are worse) causes me to investigate further, deepening my disappointment.
What you reported is unacceptable work. Doubly so because of the distances involved. If the dealer is part of a dealership group, documenting and publishing the poor work as done by the dealership group rather than the INEOS subsidiary might get traction. INEOS might not care, but dealer group reputation is something some other marques look at when handing out dealer agreements, and if that group is looking to pick up such marques this would be to their detriment, as it should be.
The offer to the dealer would be that they pay for the work at the closer dealer stateside - how they reconcile the cost recovery with INEOS not your problem. You cannot be expected to deal with another round of this. The other option is pay to get it fixed stateside and small claims court the Canadian dealer for cost recovery. It's not like you don't have evidence that you have gone above and beyond being reasonable here.
Upvote 0
This is where I'm confused. What dealer cannot do warranty work?
USA dealers cannot warranty a Canadian vehicle and vice versa. We looked into buying a Civic SI from Canada and were told the same by Honda USA.
Upvote 0
