Head light leveling?
MileHigh
That Guy
8:19 AM
Colorado
Am I stating that correctly? I saw on Ingenar’s video that there is an option for headlight leveling? Is that a dynamic thing for when installing them and getting them right, or for when you are towing or have a load that tilts the vehicle a bit? I don’t think I’ve had that as an option on my vehicles?
It's a dial on the roof switch panel with I think 5 settings
I thought this was in on one of the menus in the ‘infotainment system’?
Taken from the owners manual 👍🏼
thumb wheel located in the roof console, to the required switch position. POSITION LOAD 0 Driver only, or driver and all front seats occupied (load-space empty) 1 All seats occupied (load-space empty) 2 All seats occupied by adults (load-space at maximum) 3 Driver only (load-space at maximum)
And this is the better way of adjusting them to me as sometimes I level the lights in another way than I would do on a tarmac road. With automatic levelling that option is gone
Thanks, thought it was in the menu, couldn’t find it after watching it again…
Is the manual online yet?
It's reappeared. 🙌
Seems to be the same version as last time ~ 28th Feb 2023, Edition 1, v001.
I doubt that feature will be on the NA spec.
My Grenny has the leveling wheel. I tried it out, but it doesn't seem to work. Any ideas?
On mine, there is a slight delay of maybe a second. It's a servo, so it just slightly moves the low beams up or down, depending on the setting. I thought it was for the "working" lights since it's inside the same white line. But, the other switch is for the off-road lights and the wheel is for the headlight low beams.
Last evening was the first time I have tried the road lights. When I switched to the high beams, there is a noticeable gap between the low beam line and the high beam line. Typically there is a near seamless merging of the two lights. But, at least on mine, this does not appear to be the case. Has anyone else noticed this?
Noticed this two nights ago when driving on a dark road.
