Has anyone removed the surround for the fuel filler?
Mudnut
Quartermaster Owner
2:41 PM
Clifton Beach QLD, Australia
One of the first mods I plan to do is remove the stupid restricted fuel filler and replace with a high flow filler. I work remote, and have access to high flow nozzles only. Had a look at the dealers, and could not see how to remove the plastic panel surrounding the fuel filler.There appear to be 4 x indents on the panel..Could be for a screw driver to press? Fill pipes are available on line for around $100 AU.
Well worth it in my opinion.
Reactions: HT
Poke around - someone designed an adapter and someone else suggested a different car manufacturers adapter (I don't recall which though).
I think you want to replace the filler neck and cap, not just use an adapter/funnel? Talk to @Caveman a.k.a. GrenX.
He posted about converting to a hi-flow filler here and mentions a hi-flow filler option as part of the Brown Davis auxiliary tank upgrade on his website here. Scroll down that page to the Fuel Tank section.
Reactions: HT
Yes thanks Clark, Yes we are in testing for the replacement hi-flow filler in my vehicle. It will be sold in the kit with the aux fuel tank with estimated stock availability in June. I have seen some plastic adapters online but not sure how good they work.
